Author Topic: Pipes at rear of plenum...  (Read 264 times)
JDX
  • North Essex
    • '02 2.2dti CDX estate
« on: 27 December 2018, 14:20:51 »
I'm removing the plenum to clean up things as per one of the great guides on here.
There are four pipes at the rear of the plenum which need removing & they have a type of clip I am not familiar with. Fearful of breaking them, how are they removed / undone?
Thanks...
  • Online Online
  • Chatham, Kent
  • Rover Metro 1.8VVC
    • 3.0l Elite estate
Re: Pipes at rear of plenum...
« Reply #1 on: 27 December 2018, 14:26:04 »
Gently lift the end with a small screwdriver.
If you do damage the clamp(they're reusable if you're careful) then you can replace them with just about any clamp you favour - mine got cable ties as they're only vacuum hoses ;D
JDX
  • North Essex
« Reply #2 on: 27 December 2018, 14:47:21 »
Thanks...I will give it another go then - I have cable ties should they be needed.
  • Cornwall
    • 3.2 Project MV6 Estate
« Reply #3 on: 27 December 2018, 15:15:27 »
Assuming that the pipes are still a snug fit you can leave the clips off with no ill effects.
The pipes are all under a partial vacuum and get pulled on (rather than blown off) the spigots.
JDX
  • North Essex
« Reply #4 on: 27 December 2018, 15:35:05 »
Aah, thanks I didn't know that. One of the pipes didn't have a clip anyway but seemed to be well fitted without it.
I'm a bit of a novice but am always willing to give things a try & they normally work out OK in the end  :)
  • Online Online
  • Chatham, Kent
    • 3.0l Elite estate
« Reply #5 on: 27 December 2018, 15:37:20 »
I knew that, but it just looks wrong ;D
Migv6
  • Webs End.
    • 3.2 Elite & Merc 190D.
« Reply #6 on: 27 December 2018, 16:08:58 »
Its rare to see them still fitted. Most Omegas seem to lose them quite early in life.
Wish I didn't know now, what I didn't know then.
Tick Tock
  • Hereford
    • 2.5 V6 Facelift Estate
« Reply #7 on: 27 December 2018, 16:10:09 »
On my 3 X 2.5 V6 cars, they've never had any clips fitted  ::)
Omega 2.5 V6 Facelift Estates, a CD & a CDX both in the rare star silver colour.
  • Northampton
    • '16 Skoda, '06 BMW 650i
« Reply #8 on: 27 December 2018, 16:18:24 »
I, too, cable tie vac hoses out of habit ;D
..and it went 'dugga dugga dugga dugga' no more.
johnnydog
  • East Lancashire
    • 2.6 & 3.2 sal, 3.2 est
« Reply #9 on: 28 December 2018, 17:27:16 »
A small set of pincers (woodworking variety, not long nosed pliers) and a small thin screwdriver aid their removal, and more so the refitting of the original clips. Done it several times this way with mine.
2002 3.2 Elite saloon, 2003 3.2 Elite estate, 2003 2.6 Elite saloon
« Reply #10 on: 28 December 2018, 19:18:54 »
There is a tool for removing and refitting them without damage ;)
  • Online Online
  • Chatham, Kent
    • 3.0l Elite estate
« Reply #11 on: 28 December 2018, 22:16:29 »
Yes. Got one. Access is a bit cramped though.
Page created in 0.111 seconds with 21 queries.
