Author Topic: What's the best way....  (Read 597 times)
Sir Tigger QC
    • 2 Fords
« on: 01 January 2019, 16:54:25 »
.... to remove a welded on brake disc?  ???
I need to change the rear discs and pads on the Mondeo and made a start this afternoon, only to find that the disc is welded on.  ::)
When I did the fronts last year I smacked 7 bells out of them with the sledgey.  One came off whole, the other in pieces....  :D
Given it's New Years Day and some of the neighbours have family and friends round, I refrained being a considerate chap, so squirted lots of WD40 around and gave it some light taps with the hammer.  ::)
Tomorrow however....  ;D
Unless someone comes up with a better solution.  Heat perhaps?  ???  :-\
JC is not The Messiah, he's a very naughty boy!!
  • Over Active Thyroid
  • South Lincolnshire
  • Shami and TB forever.
Re: What's the best way....
« Reply #1 on: 01 January 2019, 17:04:09 »
Gentle manipulation with 'sledgy the hammer' should see you right.
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #2 on: 01 January 2019, 17:26:18 »
Must admit my first thought was heat,but would that run the risk of damaging the bearing in some way?Best rust buster I've found is a 50/50 mix of atf-u and acetone.Local stealer uses your primary method of "Sammy".
Migv6
  • Webs End.
    • 3.2 Elite & Merc 190D.
« Reply #3 on: 01 January 2019, 18:42:44 »
A puller ?
Wish I didn't know now, what I didn't know then.
  • Online Online
  • Up North
    • Astra 2.0 diesel
« Reply #4 on: 01 January 2019, 18:48:44 »
A puller ?
Who are you calling a puller?  ;D
If you are offended by anything I post, sorry. Just thought I'd get that in now.
Sir Tigger QC
    • 2 Fords
« Reply #5 on: 01 January 2019, 20:56:06 »
A puller ?
No special tools available.  :(
I have a range of hammers in different sizes, a blowtorch and a gurt big iron bar....  :-\   :)
biggriffin
  • huntingdon, Hoof'land
    • 02 3.2 mv6 estate.
« Reply #6 on: 01 January 2019, 21:13:13 »
Hoof'land storeman..
Omega is a barge not a dtm-touren-wagen
Sir Tigger QC
    • 2 Fords
« Reply #7 on: 01 January 2019, 21:35:55 »
Thanks BG!  :y
I havn't taken the caliper bracket off yet, but I took off the caliper and took out the disc screw, gave the disc a tap with the hammer and it's rock solid.  ::)
  • Cornwall
    • 3.2 Project MV6 Estate
« Reply #8 on: 01 January 2019, 21:50:36 »
I had this problem on the MV6 last month.
I tried a little 'light persuasion' but I wasn't prepared to hit it hard enough to make it let go.
Plan B was to take out the retaining screw and wheel bolts - started the engine, stuck it in 'drive' and applied the brake repeatedly until the disc released it's grip on the hub.  :y
The disc can't go anywhere because the caliper is holding it in place.
Edit - the drag in the gearbox is enough to turn the wheels so no need to apply lots of throttle - just press the brake each time the disc starts turning at about walking pace until it eventually lets go.
« Last Edit: 01 January 2019, 21:54:52 by Andy H »
biggriffin
« Reply #9 on: 01 January 2019, 22:01:45 »
Old school, workshop practice,, before the elf's. :y
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #10 on: 01 January 2019, 22:07:13 »
For whatever reason the mundane-o discs take quite a bit to knock off.
RIP Paul Lovejoy
Sir Tigger QC
    • 2 Fords
« Reply #11 on: 01 January 2019, 22:37:28 »
Yes it was a hell of a job when I did the fronts last year.  ::)
Ended up smashing one up...  :o
  • Cornwall
« Reply #12 on: 01 January 2019, 22:50:44 »
Oops - my reply isn't going to help in getting the rear discs off a wrong wheel drive car ::)
« Reply #13 on: 01 January 2019, 23:20:19 »
Is the hub bolted to the trailing arm?
If yes, unbolt it and place the disc face up on a couple of blocks and smash ten bells of shit out of the centre of it to knock the hub off the disc ::)
78bex
    • 2.2 CD AUTO / FAZER 600
« Reply #14 on: 01 January 2019, 23:35:08 »
OK are they deep sleepers  ??? good, won`t take you more then 30 minutes to get the job done if you start it now  ;D
I never hammer from the rear of the disc, there`s always a risk of hitting & deforming the caliper bracket  mounting points. hammer it diagonally across the front face.
The folks next door will just think you`re ringing in the new year......again  :-X
Page created in 0.117 seconds with 22 queries.
