Author Topic: What's the best way....  (Read 3032 times)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: What's the best way....
« Reply #15 on: 02 January 2019, 13:12:42 »
When they do come off, refit with some copper slip for ease of removal next time. :y
  • Chatham, Kent
  • Rover Metro 1.8VVC
    • 3.0l Elite estate
« Reply #16 on: 02 January 2019, 13:43:22 »
Wire brush the hubs first - something you should do for any hub face mounted disc. This is a perfect job for a cordless angle-grinder with a cup wire brush.
    • 2 Fords
« Reply #17 on: 02 January 2019, 16:38:37 »
Well it came off in the end with much hammering, bashing and bad language!  ;D
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #18 on: 02 January 2019, 19:46:00 »
For whatever reason the mundane-o discs take quite a bit to knock off.
Yes it was a hell of a job when I did the fronts last year.  ::)
Ended up smashing one up...  :o
It’s almost like the hub and disc hat are an interference fit  I’ve had wheel bearings pop out easier 😂😂😂
I saw one of our guys hit one repeatedly so hard until the hat separated from the disc 😧😧😧😧😧😧😂😂😂
RIP Paul Lovejoy
78bex
    • 2.2 CD AUTO / FAZER 600
« Reply #19 on: 02 January 2019, 22:27:34 »
 The fleet repair co. who serviced the vehicles for the company I last worked for used a really quick & easy method. But of course they had all the kit  8)
The technician first assembled  a 3 legged  puller on the disc & got some tension on the device & sprayed a lot brake cleaner fluid up behind the disc
He swopped the windy gun for an air hammer & hammered on the front face of the disc where it sits on the hub. I`d say after about 2 minutes of this deafening treatment & with his mate increasing the tension on the puller the disc popped off.  ;D
« Reply #20 on: 03 January 2019, 08:51:49 »
That's pretty much how I got the rear discs off the Jaguar hubs when I broke it, too.. although replace "air hammer" with "lump hammer" and "popped off" with "came off with such a bang I thought a bomb had gone off" ;D
« Reply #21 on: 03 January 2019, 16:43:19 »
The boot came off much easier. As did the engine! ;D
Page created in 0.1 seconds with 21 queries.
