Pages: 1 2 3 4 [5] 6 7   Go Down
Author Topic: Dead Beemer!  (Read 1814 times)
  • Online Online
  • Up North
    • Astra 2.0 diesel
Re: Dead Beemer!
« Reply #60 on: 09 January 2019, 18:39:30 »
Most likely a driveshaft joint stripped its splines,Beemer diffs are quite tough stuff normally  :y
I think you'd hear/feel that happening, Henry. Tigger said he lost power and didn't mention any nasty noises. It's more likely it's just popped out, I think.
But.....until the lazy bastard has a look and let's us know, it's only guesswork.
Yay!  :)
You forgot the smilie!  :y
A smiley might have made me look smug.  ;D
If you are offended by anything I post, sorry. Just thought I'd get that in now.
Sir Tigger QC
    • 2 Fords
Re: Dead Beemer!
« Reply #61 on: 09 January 2019, 18:46:55 »
Yay!  :)
You smug Uncle STEMO?  ???  Nah!  ;D
JC is not The Messiah, he's a very naughty boy!!
Re: Dead Beemer!
« Reply #62 on: 09 January 2019, 18:49:07 »
Not wanting to piss on the parade, but isn't the bit that's popped out connected to the drive shaft end by six bolts?
I suspect that the parts bill will include a new diff, two drive shafts, two hub flanges and a new swear jar... :-\
There's a decent BMW breakers over in Essex...
www.bmwspares.co.uk  :y
  • Online Online
  • Up North
    • Astra 2.0 diesel
Re: Dead Beemer!
« Reply #63 on: 09 January 2019, 18:49:20 »
Yay!  :)
Do I detect a hint of sarcasm there?
Re: Dead Beemer!
« Reply #64 on: 09 January 2019, 18:56:13 »
Yay!  :)
Surely a given ;D
  • Online Online
  • Up North
    • Astra 2.0 diesel
Re: Dead Beemer!
« Reply #65 on: 09 January 2019, 18:56:39 »
The spline May have popped out, like this chap does with his little hammer
https://youtu.be/T43vjZeBtOA
Re: Dead Beemer!
« Reply #66 on: 09 January 2019, 19:11:54 »
Quite possibly... although a more pertinent question would be how/why it's popped out :-\
Sir Tigger QC
    • 2 Fords
Re: Dead Beemer!
« Reply #67 on: 09 January 2019, 20:47:25 »
I'm thinking that there must be a circlip of some sort that holds it in and has come adrift.  :-\
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
Re: Dead Beemer!
« Reply #68 on: 09 January 2019, 21:14:12 »
There is a c-clip on the spline spigot stub that goes in to the diff. It is designed to retain the stub in a groove in the diff but is not designed for being pulled against with force. Baggy/worn suspension/worn rear subframe, that allows too much travel sideways is one of the causes. The c-clip alone will struggle to hold the stub in if sideways movement is present in the suspension. They even do a spacer that goes between the stub flange and the half shaft (6 bolt fixing that Al referred to) to try to minimise sideways movement but I believe this to be for the bimmer guys that run with high degree negative camber. Another theory is that as the spline/diff teeth wear they act like a vortex and spit the stub out.  :-\
My fun car is a 2018 Bmw F32 430d M Sport with indicators.
  • Online Online
  • Up North
    • Astra 2.0 diesel
Re: Dead Beemer!
« Reply #69 on: 09 January 2019, 21:24:03 »
Now we're getting somewhere  :y
Sir Tigger QC
    • 2 Fords
Re: Dead Beemer!
« Reply #70 on: 09 January 2019, 22:00:15 »
Yes and I was pulling a hard U-turn when I lost power!  ::)  ;)
jimmy944
  • Kidderminster
    • Swedish soot chucker
Re: Dead Beemer!
« Reply #71 on: 09 January 2019, 22:02:14 »
Well, if you will be rough with it! ::)
 ;D
  • Online Online
  • Up North
    • Astra 2.0 diesel
Re: Dead Beemer!
« Reply #72 on: 09 January 2019, 22:06:10 »
Don't mention pulling anything hard. There are people on here who make rude comments about stuff like that.  ;D
  • Online Online
  • Up North
    • Astra 2.0 diesel
Re: Dead Beemer!
« Reply #73 on: 09 January 2019, 22:13:28 »
As Columbo would say 'Just one more thing'.
The guy in the vid I posted didn't seem to remove any C clip before he podged the stub axle out.  :-\
Re: Dead Beemer!
« Reply #74 on: 09 January 2019, 22:23:10 »
Have you had the wheel bearing on that side replaced?
Wonder if the wrong bearing was fitted and has allowed the shaft to move :-\
Pages: 1 2 3 4 [5] 6 7   Go Up
Page created in 0.112 seconds with 21 queries.
