Author Topic: heater fan push switches on main dash panel  (Read 624 times)
Toledodude1973
  • IPSWICH U.K.
  • 2002 2.6 elite,1973 ,Gas van,1974 victor fe
    • 2.6 OMEGA ELITE 2002
« on: 04 January 2019, 20:24:53 »
Hello i have an issue with the fan  switch area on my 2002 elite 2.6 which became kind of sticky. i attempted to clean off the stickyness with spray dash cleaner but ended up taking the black off the small fan control switches and the other two switches on that panel.
I would need to replace the whole panel which includes boot release and rearblind amongst other things.
my question is how easy is it to replace the panel(the one that surrounds the stereo)and can i get hold of a used one ?
thanks for help
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
Re: heater fan push switches on main dash panel
« Reply #1 on: 04 January 2019, 20:29:31 »
Just as easy to swap out the buttons  ;)
Toledodude1973
  • IPSWICH U.K.
« Reply #2 on: 04 January 2019, 20:39:10 »
thanks DG how do they come off?
« Reply #3 on: 04 January 2019, 21:26:52 »
Carefully  ::)
You need to split the unit... Easier to do than to try to explain  ;)
  • Millennium Man
    • The missus mad
« Reply #4 on: 05 January 2019, 09:54:33 »
Has the damage gone beyond the climate panel?  If not, simply swap the climate ecu/panel over if you can find a perfect one, or swap buttons over if you cant find a perfect one. Patience is needed to dismantle ecu to get to buttons due to lots of plastic clips, but remains an option.
If the damage has fone beyond that climate strip, you need to replace those bits as well - they all have to come off anyway to get climate panel out.
I don't tolerate bickering, and I'm always grumpy.
And Lizzie Zoom says I'm a heartless bastid...and she's absolutely correct!
Toledodude1973
  • IPSWICH U.K.
« Reply #5 on: 05 January 2019, 19:15:09 »
Thanks for reply the damage is mainly the fan + and - buttons so a replacement climate panel is what i need ,is that right? If i dont just change buttons.
  • Millennium Man
    • The missus mad
« Reply #6 on: 06 January 2019, 18:46:34 »
Yup, replacement climate panel, if you can find a perfect one.  If you find one that has good fan buttons but poor Auto/Eco/Off (the other ones that tend to go), then that's an option, and make one good on from the 2 bad...
Toledodude1973
  • IPSWICH U.K.
« Reply #7 on: 06 January 2019, 19:57:49 »
thankyou ill put add in wanted for climate panel :y
Toledodude1973
  • IPSWICH U.K.
« Reply #8 on: 08 January 2019, 20:43:25 »
Will the climate/heater panel be the same on a 2.2 f/l same year as mine,as my 2.6 elite? one is being broken on ebay
« Reply #9 on: 08 January 2019, 22:42:09 »
 ;D ;D ;D
Sorry, couldn't help that...
It will fit, and work, perfectly  :y
All facelift Omegas have climate control as standard.
Toledodude1973
  • IPSWICH U.K.
« Reply #10 on: 09 January 2019, 18:55:41 »
Thanks DG just got reply from ebayer and panel is in poor condition  :y
Migv6
  • Webs End.
    • 3.2 Elite & Merc 190D.
« Reply #11 on: 09 January 2019, 19:51:20 »
Tried Omegas52 on ebay ?
Wish I didn't know now, what I didn't know then.
Toledodude1973
  • IPSWICH U.K.
« Reply #12 on: 10 January 2019, 17:41:59 »
i'll give him a try thanks  :-\
Page created in 0.108 seconds with 21 queries.
