Author Topic: AUXILLARY BELT TENSIONER  (Read 2465 times)
golly
« on: 06 February 2019, 13:04:38 »
Hi all, can anyone recommend someone who can fit a Auxillary belt tensioner to my 2.6 V6 ?...i am in Feltham ( the posh end ) nr Heathrow. or is there another way way of just replacing a new Pulley to the old assembly ?
Kind regards Glen
Re: AUXILLARY BELT TENSIONER
« Reply #1 on: 06 February 2019, 13:34:14 »
New pulley readily and cheaply available from Vauxhall. New belt might also be a prudent purchase, although not essential if ok.
In Sussex, but occasionally pass that way... Not a particularly arduous job though :y
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #2 on: 06 February 2019, 13:40:17 »
As DG says I'd take the precaution of changing the belt too.Tensioner pulley is only held by one bolt[15mm spanner/socket?]so I'd just change the pulley and not the whole tensioner,unless you know of some kind of fault with the tensioner.
golly
« Reply #3 on: 06 February 2019, 14:36:06 »
Thanks for the quick reply. I have a new belt and complete tensioner assembly, to fit the whole thing looks too involved, i.e removal or ram intakes etc.. I was advised by RAC that it wasn't a difficult job, so provided i can get just the pulley ,it looks a pretty straight forward as you said.
Thanks again chaps.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #4 on: 06 February 2019, 17:58:14 »
Thanks again chaps.
Taking the Rams Intake, Penluim etc off is a fairly easy job, its getting the Belt fitted correctly thats important, why would the RAC man be talking at you, has something all ready happened to it.
