Author Topic: Door Puddle Light  (Read 328 times)
Lizzie Zoom
  • Ashford, Kent
    • Omega 3.2 V6 ELITE 2003
Door Puddle Light
« on: 06 February 2019, 15:38:33 »
The drivers door puddle light has stopped working.  Changed bulb with unit still in the door, but still no light.
Obviously I have managed to prise out the 'glass' of the light unit, but I know the main body of it should also be coming out as per the Haynes Manual, but what is the best way to do so without breaking the plastic please?
Seems to be quite resistant in my early attempts to remove; is there a trick to it please?
Cheers :y
  • Solihull
    • 3x 3.2 V6 Elite Saloons
Re: Door Puddle Light
« Reply #1 on: 06 February 2019, 18:15:12 »
Does the door switch work?
Lizzie Zoom
  • Ashford, Kent
« Reply #2 on: 06 February 2019, 18:37:03 »
Yes, or at least the interior lights go on and off as the door is opened and closed.
« Reply #3 on: 06 February 2019, 19:21:29 »
Any recent door work? ie central locking :-\
Lizzie Zoom
  • Ashford, Kent
« Reply #4 on: 06 February 2019, 19:29:45 »
No DG, nothing done to the door at all thanks.
Can the connector plug to the light unit work loose as the door is constantly opened and closed?
I want to get behind the light unit but as I said I am afraid of breaking the stubborn thing. ;)
« Reply #5 on: 06 February 2019, 19:33:33 »
There's a notch top and bottom towards the 'wider' iirc end... Insert a couple of wooden coffee stirrers and push the tabs towards each other and pop the unit out.
The lens shouldn't be removable... (it's bonded on)  ::)
  • Solihull
« Reply #6 on: 06 February 2019, 19:38:17 »
The lens shouldn't be removable... (it USED TO BE bonded on)  ::)
Nope never done that before, nope, never  ::)
  • Chatham, Kent
  • Rover Metro 1.8VVC
    • 3.0l Elite estate
« Reply #7 on: 06 February 2019, 19:43:51 »
I've never had to araldite all four lenses back on either........
« Reply #8 on: 06 February 2019, 19:44:15 »
Not that I would admit to :-X
 ;D
Lizzie Zoom
  • Ashford, Kent
« Reply #9 on: 06 February 2019, 20:07:00 »
Thanks DG, the lens came off easily with it having fastening tags top and bottom.
I will now use your tip to get the rest out :y
« Reply #10 on: 06 February 2019, 20:32:32 »
They are only there to hold it in place whilst the bondong sets ;)
Lizzie Zoom
  • Ashford, Kent
« Reply #11 on: 07 February 2019, 10:39:25 »
Thanks DG :y
I tried your method of removal and it worked a treat!! :-* :-* :y
Never worked on a car before with two old fashioned spoons, but hey any tool that does the job is fine by me!
The rear connector had worked loose and as soon as I pushed it firmly on the light came to life 8) 8)
Many thanks DG :-* :-* :y
Page created in 0.113 seconds with 22 queries.
