Author Topic: Low voltage at Radio fuse  (Read 183 times)
MarkEastwood
  • Stoke on Trent
    • 1998 Omega Elite Estate
« on: 17 February 2019, 15:53:06 »
Hi guys
New to this forum but hoping for some guidance.
I recently recharged my battery and found my radio was no longer working.  I checked the radio fuse and it was intact but the found it was only registering about 3 volts at the terminals.
Everything else seems to be working but I'm not sure where to go next.
Can anyone point me in a direction?
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Low voltage at Radio fuse
« Reply #1 on: 17 February 2019, 21:04:08 »
Well 3 Volts doesn't make sense unless your measuring stray volts or leakage through another source.
Obviously check the Meter is working correctly by measuring a known source, check any cables you may have left off when changing the Battery, otherwise just work your way backwards from the HU Supply to Battery.
Page created in 0.094 seconds with 22 queries.
