Author Topic: Management light on  (Read 27719 times)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Management light on
« on: 18 April 2019, 19:07:59 »
In the 9 years I've owned the 3.2, I've never had the EM light on. Took it in with no light on for its MOT today, after giving it an Italian tune-up. It passed with one advisory, EM light on >:(. What did they do? WOT didn't bring it on for me. >:( >:( >:(
Re: Management light on
« Reply #1 on: 18 April 2019, 19:12:09 »
Probably left it idling whilst they had lunch...
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #2 on: 18 April 2019, 19:17:14 »
you should count yourself very lucky
should have been a fail  :o
I guess the NT has not read the MOT manual for a year or so  ;D
« Reply #3 on: 18 April 2019, 19:32:04 »
If you are in the RWB area either before 12 tomorrow, or after 3 from Tuesday to Friday next week I can stick the code reader on for you, away in the tin tent otherwise :)
Shackeng
  • Ramsbury
« Reply #4 on: 18 April 2019, 22:09:19 »
Ta, it will have to be next week. Thanks Nige, I'll be in touch. Meantime can someone PM me with a cheapo reader that will reset codes please? :y
Shackeng
  • Ramsbury
« Reply #5 on: 18 April 2019, 22:10:37 »
Advice was that its not a fail for this age of vehicle. ??? ??? ???
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #6 on: 18 April 2019, 23:01:30 »
« Reply #7 on: 19 April 2019, 13:21:51 »
Esp when they know they were responsible for putting it on in the first place.
Shackeng
  • Ramsbury
« Reply #8 on: 19 April 2019, 15:53:41 »
Has anyone got a generic code reader that will reset codes they can recommend for an Omega 3.2? If so please PM me the name. :y
I am surprised that no-one has come up with a reason that may have brought the light on during the MOT. I am not a great fan of such coincidences. :-\
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #9 on: 19 April 2019, 15:55:37 »
3.2 is OBD compliant, so any cheap device ought to do what you want. Easily doable for under £20.
Shackeng
  • Ramsbury
« Reply #10 on: 19 April 2019, 16:02:36 »
:y :y :y
« Reply #11 on: 19 April 2019, 16:04:13 »
Ahem... They probably left it idling for an extended period.
Pedal trick will tell what the car thinks the cause was :y
Shackeng
  • Ramsbury
« Reply #12 on: 19 April 2019, 16:16:12 »
Just off to do that. It can't have idled for long, it only took 20 minutes to do the MOT!
« Reply #13 on: 19 April 2019, 16:18:26 »
Only needs to miss slightly once... Fans kicking in could cause a stutter as the load increases ;)
Shackeng
  • Ramsbury
« Reply #14 on: 19 April 2019, 16:37:35 »
Pedal trick doesn't work for some reason. Spanner light remains on. IIRC I have used it in the past, but I may be confusing it with the TD. Paperclip doesn't appear any use as no connectors in 2 & 6 of OBD socket. :(
Pages: [1] 2 3 4  All   Go Up
