Author Topic: Ocassional stalling  (Read 256 times)
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
Ocassional stalling
« on: 01 May 2019, 07:33:02 »
Tickover when up to temperature on my 3L is 500revs or just a tad below,however once in a while[there's no set pattern of time/distance/conditions]when slowing down to a stop at traffic lights/roundabouts the revs will drop further momentarily before recovering and sometimes it doesn't recover and stalls taking two or three attempts to get it to re-start which can make things a bit of a lottery when driving out and about.I'm thinking possible IACV problem or throttle body needing a clean? do these sound feasible?Any other ideas?
Enceladus
  • London
Re: Ocassional stalling
« Reply #1 on: 01 May 2019, 08:22:59 »
Sounds like a classic case of a failing crank position sensor. Read the fault codes and report back.
Migv6 le Frog Fan
  • Webs End.
    • 3.2 Elite & French Hatch
« Reply #2 on: 01 May 2019, 13:19:25 »
I would also clean and lube the ICV.  :y
Wish I didn't know now, what I didn't know then.
biggriffin
  • huntingdon, Hoof'land
    • Vectra in a posh frock.
« Reply #3 on: 01 May 2019, 14:05:49 »
Clean icav, throttle bodies, and check that icav is airtight, if still doing this then new crank sensor.
Hoof'land storeman..
Rwd-less..
terry paget
  • Midsomer Norton Somerset
    • 1 Omega 3 Astras 1 Vectra
« Reply #4 on: 01 May 2019, 15:06:45 »
If all above fail, it could me the mass air flow sensor (MAF), easily checked by unplugging it (bringing on the EML) and seeing if the fault disappears.
BazaJT
« Reply #5 on: 01 May 2019, 20:01:23 »
I think I'll go with swapping IACV[I've got a new one in stock]and cleaning throttle bodies and see how it fares with that.
Page created in 0.181 seconds with 21 queries.
