Author Topic: Colours of coolant temp sensors  (Read 1066 times)
    • Zafira Tourer x2 SRi & SE
Re: Colours of coolant temp sensors
« Reply #15 on: 03 May 2019, 15:48:23 »
How can I prove thermostat is stuck open
Haven't heard my fans come on for a while
Fact you mention it's not getting up to operating temp of around 90, and it's stuck around 80 is a clear suggestion is stat, also most common cause and well known for them to get sticky.
Also get the coolant transfer pipe as they are a pig to separate and pipe often breaks.  :y
Got a VW, Audi, Skoda or Seat? I have full Diagnostic software VCDS to read and program your car. Need something enabling? Perhaps full diagnostic? Drop me a PM. Can diagnose in Camberley or Osterley Area.
    • R320 TDM850 SmartRoadster
« Reply #16 on: 03 May 2019, 16:24:37 »
Start the engine from cold and keep an eye on the temp of the top hose. If it gradually gets warm as the engine gets warm, then the 'stat is stuck open. The top hose should stay cold up to the point of the 'stat opening at which point it should suddenly get hot.  :y
« Reply #17 on: 03 May 2019, 16:50:51 »
Classic Stat. They usually fail open.  :y
CTS fails to -40c causing massive over fuelling... Only starts from cold and then runs like an absolute dog once warm and then won't start.  :y
biggriffin
  • huntingdon, Hoof'land
    • Vectra in a posh frock.
« Reply #18 on: 03 May 2019, 17:20:34 »
for the price of a stat, just replace it.
Hoof'land storeman.
j3lly
    • Vectra GSi
« Reply #19 on: 03 May 2019, 18:02:37 »
Coolant transfer pipe are you talking item 15 here
Thanks
j3lly
    • Vectra GSi
« Reply #21 on: 03 May 2019, 18:36:11 »
School boy error
https://vauxhall.7zap.com/en/car/j96/f/0/26-2/
biggriffin
« Reply #22 on: 04 May 2019, 09:28:27 »
School boy error
Think there's some parts available in the relevant section, from different members, might be worth a look  ::)
Hoof'land storeman.
j3lly
    • Vectra GSi
« Reply #23 on: 04 May 2019, 13:58:10 »
Just done some checks with basic diagnostics ( Torque Pro )
here are the results
Rad top hose out of thermostat starts to get warm at 70'
Whats interesting ( To me anyway )
The 2 smaller dia pipes going to header tank
One gets warm as car warmed up the other only stated to get warm at 70'
A noticeable difference
Rad fans kicked in at 98'
Unsure now
Any thoughts
« Reply #24 on: 04 May 2019, 14:15:28 »
Stat is still stuck open...
That pipe goes from vaguely warm to hot the instant the s stat opens if it's working  :y
biggriffin
« Reply #25 on: 04 May 2019, 15:19:33 »
Get it changed, why wait for it to jam closed, you are 99% sure it's faulty.
Hoof'land storeman.
Page created in 0.114 seconds with 21 queries.
