Author Topic: Oil extractor pumps  (Read 695 times)
Auto Addict
  • North Birmingham
  • Merc to annoy TB
    • MB C-class Estate
Oil extractor pumps
« on: 07 May 2019, 18:49:31 »
Don't you just love them :y
Should have bought one years ago. :'(
Merc lover
  • Chatham, Kent
  • Rover Metro 1.8VVC
    • 3.0l Elite estate
Re: Oil extractor pumps
« Reply #1 on: 07 May 2019, 23:11:50 »
I've used them, and can't see the point on an engine with a drain plug. They're not going to work on a gearbox or diff which is full of gears.
There are better things to buy/use/keep
    • R320 TDM850 SmartRoadster
« Reply #2 on: 07 May 2019, 23:38:02 »
I bought a Pela for my Smart ....no drain plug fitted.
They're the future   :y
  • Online Online
« Reply #3 on: 08 May 2019, 00:23:06 »
Drain plugs?
Migv6 le Frog Fan
  • Webs End.
    • 3.2 Elite & French Hatch
« Reply #4 on: 08 May 2019, 00:25:29 »
Never used one and hopefully never will.
Luddite ? Me ? How very dare you.  :D
Wish I didn't know now, what I didn't know then.
Sir Tigger QC
    • 2 Fords
« Reply #5 on: 08 May 2019, 00:31:49 »
I've never used one, but can see the attraction especially where the oil filter is in the engine bay, so there is no need to jack the car and crawl underneath.  :)
JC is not The Messiah, he's a very naughty boy!!
« Reply #6 on: 08 May 2019, 09:08:33 »
Drain plugs?
Do we have a smart arse smilie?  :P
raywilb
  • york
    • 2.2dth gtx estate
« Reply #7 on: 08 May 2019, 11:47:54 »
  i did once buy one from lidl. draining out the oil via the dipstick tube was ok , it worked a lot quicker when the oil was hot. let a friend use it & never saw it again.
  • Chatham, Kent
    • 3.0l Elite estate
« Reply #8 on: 08 May 2019, 12:04:51 »
crawling under the car allows you to do the basic visual inspection that is part of the service schedule. That's a good way to avoid BFO.
I prefer to make gravity empty the sump rather than hope it's sucked dry. There are better places for that.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #9 on: 08 May 2019, 12:57:42 »
100% agree  :)
I also think that a garage or MOT tester should get the blissfully unaware driver to see all the bits that are falling off/badly worn etc to better educate them on the need for regular checks
not that that will happen  :(
  • Over Active Thyroid
  • South Lincolnshire
  • Shami and TB forever.
« Reply #10 on: 08 May 2019, 13:32:11 »
If the filter is easily accessible in the engine bay then worth a go.
If under the car not much point......
  • Millennium Man
    • The missus mad
« Reply #11 on: 08 May 2019, 17:40:17 »
Mine has a suction tube (I suspect an afterthought of what to do with the dipstick tube it was probably initially going to have ;)) and a sump plug.
Like Nick W, emptying the oil from sump plug is my preference. But the 20,000 screws holding the undertray on means invariably the pump is used.
I don't tolerate bickering, and I'm always grumpy.
And Lizzie Zoom says I'm a heartless bastid...and she's absolutely correct!
  • Millennium Man
    • The missus mad
« Reply #12 on: 08 May 2019, 17:41:42 »
I wouldn't use a pump on a car without a dedicated suction tube. Relying on a flexi tube down a dipstick hole is going to end in a half arse job, best case scenario.
« Reply #13 on: 08 May 2019, 18:16:33 »
As above, my Smart Roadster doesn't havd a sump drain plug so the oil has to be sucked out. I'd to remove the dump pan so used my Pela first, there was next to no oil left in the pan when removed.
Sir Tigger QC
    • 2 Fords
« Reply #14 on: 08 May 2019, 21:20:59 »
Dump pan?  ???  ::)  ;D
Page created in 0.13 seconds with 21 queries.
