Author Topic: Is this normal?Problem spoiler omega estate  (Read 259 times)
olm
  • spain
    • 2.6 v6 sport estate
« on: 07 May 2019, 19:54:57 »
Hi. This form of the gate is like that? I thought it was not to find the roof
But when putting the spoiler...
Is normal?
Re: Is this normal?Problem spoiler omega estate
« Reply #1 on: 07 May 2019, 21:15:21 »
That dent shouldn't be there... :-\
Are the gas struts worn allowing the tailgate to go too far up?
Spoiler should fit with no gaps and it won't touch the roof when the tailgate is opened :y
olm
  • spain
« Reply #2 on: 07 May 2019, 21:42:48 »
It seemed strange to me already. The spoiler looks like it's not going to touch but if I take out the dent it will touch. The struts are ok, and to not touch it should open much less, It seems very strange to me to open so little, but if it do not have to take that form, something will have to be done
« Reply #3 on: 07 May 2019, 22:23:25 »
The spoiler is designed to not touch, so it might be that the dent is affecting the positioning :-\
Try moving the spoiler back and down 5mm... Ignoring the dent for a moment, how does the rest of it seem?
olm
  • spain
« Reply #4 on: 07 May 2019, 22:30:08 »
The spoiler donīt touch the roof, is perfect, but, if I repair the dent, I think it will touch the roof, look how close it is in the images. Rare, rare
« Reply #5 on: 07 May 2019, 22:34:57 »
It won't  :y
Don't repair the dent and the spoiler will highlight it as it will have either a gap or lots of mastic showing...
olm
  • spain
« Reply #6 on: 07 May 2019, 22:46:22 »
It won't  :y
I will think to see what I do, logically so it can not go. Thanks!
« Reply #7 on: 08 May 2019, 00:19:15 »
Had spoilers on all my estates, never touched the roof, although it is close :y
Phil
« Reply #8 on: 08 May 2019, 06:57:05 »
Wouldn't worry as when you have the spoiler fixed the aerial will smash against the spoiler and scratch it/ damage the aerial base.
There was a little metal bit that went in the aerial base on the estate that changed the angle of the whip so it didn't hit, but these corrode in and when you change the whip it gets stuck and you end up damaging the base, so change to a stub aerial first would be my advice
biggriffin
  • Online Online
  • huntingdon, Hoof'land
    • Vectra in a posh frock.
« Reply #9 on: 08 May 2019, 07:32:09 »
There should be angled spacer on the aerial to stop it hitting the spoiler. NLS from GM,  :)
Hoof'land storeman..
Rwd-less..
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #10 on: 08 May 2019, 20:21:54 »
Dont fit the extra metal angle piece on the Aerial Base if you have a Phillips or NCDC Factory Phone Kit fitted with the HU.  ;)
biggriffin
  • Online Online
« Reply #11 on: 08 May 2019, 20:25:25 »
There's 2... Do you mean the factory ball joint affair, or the Imesher angled block.
Rwd-less..
zirk
  • Epping Forest
« Reply #12 on: 09 May 2019, 19:25:48 »
Almost certainly the Ball Joint one, but I cant remember what the Irmy one looks like (picture anyone?) but guessing it will add additional spacing between the whip and Base then its a no no.
« Reply #13 on: 09 May 2019, 19:57:35 »
I just used a 1"x1/2" strip of speed tape on the back upper edge of the spoiler to give it something to rub against without damaging anything else :y
Page created in 0.117 seconds with 22 queries.
