Author Topic: ar 35  (Read 1074 times)
nellys coupe
  • buckinghamshire
    • hyundai coupe
ar 35
« on: 19 May 2019, 20:45:56 »
hi folks ive just brought an ar35 with torque converter will i need to change the gearbox ecu or what else will i need to fit it. :y
coupe rebuild master
Migv6 le Frog Fan
  • Webs End.
  • Nicole's Papa
    • 3.2 Elite & Welsh Hatch
Re: ar 35
« Reply #1 on: 19 May 2019, 20:50:55 »
Should be a straight swap as far as I remember. Only difference is one or two internal components are stronger than the AR25.
Plastic Welsh hatchbacks are awesome.
2020 can far cough.
  • Solihull
    • 3x 3.2 V6 Elite Saloons
Re: ar 35
« Reply #2 on: 19 May 2019, 21:36:40 »
Is this being fitted to a 2.6? If so it's worth getting hold of the ECU off the 3.2 as well - despite the ECU's supposedly being identical, fitting one that was from a 3.2 was the only thing that cured that horrid 2.6 'hang onto a low gear' syndrome that my old 2.6 (and most other 2.6 auto's I've driven) suffered with, can only assume it has a slightly different map?!?!
nellys coupe
  • buckinghamshire
    • hyundai coupe
Re: ar 35
« Reply #3 on: 19 May 2019, 21:37:56 »
its going onto a 2.5 mate  :y
nellys coupe
  • buckinghamshire
    • hyundai coupe
Re: ar 35
« Reply #4 on: 19 May 2019, 21:38:34 »
  • Solihull
Re: ar 35
« Reply #5 on: 19 May 2019, 21:40:05 »
Cool, different ECU from a 3.2 / 2.6 then  :y
nellys coupe
  • buckinghamshire
    • hyundai coupe
Re: ar 35
« Reply #6 on: 19 May 2019, 21:48:08 »
biggriffin
  • huntingdon, Hoof'land
    • Vectra in a posh frock.
Re: ar 35
« Reply #7 on: 20 May 2019, 16:06:44 »
Very interested, how much did you pay, just for research purposes.. :)
Hoof'land storeman.
DrAndyB
  • Neston / Cheshire
    • 2.5 V6 CDX Manual (MFL)
Re: ar 35
« Reply #8 on: 20 May 2019, 20:48:18 »
biggriffin
Re: ar 35
« Reply #9 on: 21 May 2019, 17:46:43 »
One of the Bay of Flea ( https://www.ebay.co.uk/itm/VAUXHALL-OMEGA-3-0-V6-X30XE-AUTOMATIC-GEARBOX-TORQUE-CONVERTER-GM-AR35-DN/143229589193?hash=item21592616c9:g:zbIAAOSwUgxcwxao) for 150 of your notes  ;)
 That one is 180, delivered.  So best mines a wee bit cheaper then. :)
Hoof'land storeman.
Re: ar 35
« Reply #10 on: 21 May 2019, 18:12:55 »
If you are just changing the hydromechanicals of the gearbox and nothing else, then nothing to do ECU wise.
If doing the engine, the TCM ideally needs to be programmed for that engine to get right change points.
I own a Zafira, I'm allowed to feel depressed.
Page created in 0.138 seconds with 22 queries.
