Author Topic: Pas pipe advice needed  (Read 4548 times)
Greenbay packer
  • North Devon
« on: 23 May 2019, 10:20:07 »
Hello everyone,
I have a leak from a badly rusted pas pipe of my 1996 V6 estate and would appreciate some information about the part. Its the lower of the two pipes visible in the gap in the front bumper wraparound. Its course is a bit difficult to trace but as far as I can see one end finishes at a jubilee clip more or less below the air filter box and the other end fits to the pas pump. I'd be grateful for answers to all or any of the questions below please.
1) have I traced the course of the pipe correctly and is it easy to remove?
2) does anyone have the part number for this pipe and can you tell me if it was common to all Omegas or just to the V6?
3) does anyone know where I can get one of these pipes either new or good secondhand?
4) if I get desperate could the pipe be repaired by cutting back to a good part of the steel pipe and adding a section of hose secured by jubilee clips, or will there be too much pressure in the system to get the clips to seal?
Thanks for all advice given. I was planning add some photos but can't find a way of doing so here without signing up to photobucket - is there a way to do this?.
Graham
biggriffin
  • huntingdon, Hoof'land
    • Vectra in a posh frock.
Re: Pas pipe advice needed
« Reply #1 on: 23 May 2019, 10:30:56 »
Griffin thinks how much,and how to package it up to post.. ::)
Hoof'land storeman.
  • Online Online
  • Chatham, Kent
  • Rover Metro 1.8VVC
    • 3.0l Elite estate
« Reply #2 on: 23 May 2019, 11:35:20 »
Option 4. It's ugly, but that's the only 'problem' with it.
Easy,  cheap and you could have it done before lunch.  >:(
« Reply #3 on: 23 May 2019, 17:16:04 »
He's not angry with you, GP, he just has extremely fat fingers.  ;D
  • Online Online
  • Chatham, Kent
    • 3.0l Elite estate
« Reply #4 on: 23 May 2019, 17:42:25 »
yeah.
Touch screens: they're crap for typing on
Greenbay packer
  • North Devon
« Reply #5 on: 23 May 2019, 19:22:26 »
Thanks, so its not under high pressure then and jubilee clips should seal it?
Greenbay packer
  • North Devon
« Reply #6 on: 23 May 2019, 19:26:16 »
Looking at it again I may not have traced the course of the leaking lower pipe correctly on the passenger side of the car - I thought it was going to the pas pump but maybe not, can anyone confirm please?
  • Online Online
  • Chatham, Kent
    • 3.0l Elite estate
« Reply #7 on: 23 May 2019, 23:29:45 »
a correctly sized Jubilee clip will work on any pressurised system you'll find on these cars. PAS isn't particularly high pressure.
Greenbay packer
  • North Devon
« Reply #8 on: 24 May 2019, 09:28:01 »
Thanks for that - I had visions of replacing one leak with two new ones!
LC0112G
« Reply #9 on: 24 May 2019, 09:44:08 »
I measured the pressure on the LC a few weeks back. At the output from the pump it's 95-100 bar, or 1500psi ish, on full lock. So I wouldn't want anything other than a faultless pipe between the pump and the steering box because a leak in a 100 bar pipe is going to spray fluid a long way and make a hell of a mess.
The other pipes, including the ones from the box back to the reservoir via the radiator carry much less pressure and are eminently bodge-able. Just be aware that the fluid does get quite hot (hence the need for a rad.
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #10 on: 24 May 2019, 10:34:02 »
I may have misread this, but it seems BG offered you one in the second post. :-\
Greenbay packer
  • North Devon
« Reply #11 on: 24 May 2019, 10:45:14 »
I feared that this might be the case.
annihilator
  • Wirral
    • 2 Jags XKR/JR
« Reply #12 on: 25 May 2019, 16:36:36 »
I had the very same problem a few months back and chose option 4 albeit with 2 clamps at each end and have had no problems since, there is no cooler rad for the pas system as it relies on the pipe loop in that gap in the bumper for it's cooling effect.
Greenbay packer
  • North Devon
« Reply #13 on: 26 May 2019, 14:09:19 »
Thanks for this reply. I'm probably going to have a go at repairing as there's not a lot to lose, but what to know where I can get hold of a pipe if it doesn't work.
Greenbay packer
  • North Devon
« Reply #14 on: 26 May 2019, 14:10:33 »
I've messaged him and he's going to get back to me in a week or two.
Page created in 0.021 seconds with 22 queries.
