Author Topic: Bit of a wierd LPG problem.  (Read 20767 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: Bit of a wierd LPG problem.
« Reply #30 on: 05 June 2019, 12:26:36 »
The LPG pressure is measured and regulated relative to whatever's in the intake manifold. If the engine is idling this will be about 0.3 bar. If it's stopped or flat out it'll be 1 bar.
With the engine running, the MAP pressure is indeed 0.3 bar but the lpg pressure is holding at 0.6 - 0.3 bar depending on what the stag software setting is .........
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #31 on: 05 June 2019, 13:05:34 »
Okay, a bare one for one replacement from Tinley delivered to these parts is £222.20  :(
Anybody know of any discount codes ?
« Reply #32 on: 05 June 2019, 14:00:25 »
Hmm. Something odd here.
Even if the vapouriser is drawing vapour out of the tank rather than liquid, I would expect it to muster a bit of pressure.
Can you start it, switch it over to LPG then swap each injector back to petrol, and see what happens to the vapour pressure?
BTW: the brass item sounds like a filter. Might be worth checking it's not clogged before going too much further.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #33 on: 05 June 2019, 14:14:33 »
Absolutely no chance of starting anything at the moment Kev.
Due to the tank been 2/3 full, i've been undoing a few things at the back end to relieve some of the pressure  ;)
All i'll say is thank god everybody is at work and there is a nice strong wind blowing  ;D.
One it has cleared so I can start it again, i'll have a play but to be honest, i'm wondering if that brass filter which bolts onto the KME Gold reducer is bunged up or collapsed  :-\
Still doesn't explain why it behaved before / after a fast drive and top up (as in the first few posts)
« Last Edit: 05 June 2019, 14:16:15 by tigers_gonads »
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #34 on: 05 June 2019, 15:37:19 »
Okay, brass filter removed off the side of the reducer .......... Clear  :y
Feed pipe from the tank to the brass filter .......... Clear   :y
I've also had the fill valve out of the tank. I can confirm it has no discolouration / residue on it  :y
I will need to remove the tank to get safe access to the solenoid valve hence trying everything else first  :)
« Last Edit: 05 June 2019, 15:43:24 by tigers_gonads »
« Reply #35 on: 05 June 2019, 15:42:45 »
Do you have a filter in the vapour gas line from the evaporator to the injector manifolds ?? That's the one that showed up my problem as it is a very fine filter
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #36 on: 05 June 2019, 15:44:27 »
Yes, there are 2 inline filters Nige.
1 for each bank of injectors  :y
I'll check them next but I do tend to change them every couple of years / approx 10,000 miles  :-\
« Last Edit: 05 June 2019, 15:47:31 by tigers_gonads »
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #37 on: 05 June 2019, 16:07:48 »
Right, it would seem that I cannot get a gas tight seal on the tank so its been removed on safety grounds and dumped in my back garden.
That way I can make the car safe to run on petrol for work ect.
If I can see nothing else I will take the tank out into the countryside and vent / remove the solenoid valve and see if its breaking down like Nige's did  :-\
Thanks so far lads and all idea's still welcome  :y
« Reply #38 on: 05 June 2019, 16:59:04 »
Yep, now sit back, light up a cigar and delight in a job well done.  :y
Oh, wait!  :-X
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #39 on: 05 June 2019, 17:11:03 »
Oh, wait!  :-X
 ::) ;D ;D
Just a observation from the last 200 miles on petrol
It definitely does go better on the expensive stuff  :y
According to the MID, I managed a distinctly Tunnie like 32 mpg  on the way down to the van :y
But don't worry  ;)
I soon got very board and its back down to 20.6 mpg over 200 miles  ;D ;D
« Reply #40 on: 05 June 2019, 17:13:29 »
Oh, wait!  :-X
Careful, Hull will end up looking like Brackley...
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #41 on: 05 June 2019, 17:21:48 »
Oh, wait!  :-X
The wife is on about having a BBQ this weekend  :-X ;D
I'd take a note of your post count, quick  ;D
Or is TB over it now  :-\ ;D
« Reply #42 on: 05 June 2019, 18:35:25 »
Last time he culled my post count I never did get it back.. easy come, easy go ;D ;D
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #43 on: 06 June 2019, 11:04:04 »
I'm sure you deserved it  ;D
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #44 on: 06 June 2019, 11:09:04 »
What is the gas tight blue sealant which is used to seal the threads on the tank ?
Pages: 1 2 [3] 4  All   Go Up
