Author Topic: Tightening torque of drive shaft to wheet journalismi flange  (Read 646 times)
polilara
  • Finland
    • 2.6 Y26SE Elegance 2001
Cannot find the list of torque anymore, where is it? Is the right torque with old bolts just 50 Nm as in guide here or 50Nm +60+15 degrees what is in GM guide. What to use here?
polilara
  • Finland
Re: Tightening torque of drive shaft to wheet journalismi flange
« Reply #1 on: 26 May 2019, 08:24:49 »
How to edit the Topic, automatic text correction did something strange, I am talking about Wheel Journal Flange.
polilara
  • Finland
« Reply #2 on: 26 May 2019, 12:38:51 »
Rear bearing job almost jobbed, still missing torque of those six flange bolts, please help.
ronnyd
  • Online Online
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #3 on: 26 May 2019, 15:10:59 »
If it,s driveshaft to hub, Haynes says 50nm. Have you got a Haynes, as it goes on to mention 2 further stages of tightening? HTH.
polilara
  • Finland
ronnyd
  • Online Online
« Reply #5 on: 26 May 2019, 16:10:52 »
Quote from Haynes, "Driveshaft to hub".
                                Stage1                 50nm
                               Stage2                 Tighten a further 60 deg
                               Stage3                     "        "     "      15deg
Doesn,t mention using new bolts.
polilara
  • Finland
« Reply #6 on: 26 May 2019, 16:21:54 »
OK, then I do it like that as GM says the same, thanks.
ronnyd
  • Online Online
« Reply #7 on: 26 May 2019, 16:43:40 »
Good luck. :y
polilara
  • Finland
« Reply #8 on: 26 May 2019, 17:03:16 »
Thanks, perhaps they all snap as not new...
biggriffin
  • huntingdon, Hoof'land
    • Vectra in a posh frock.
« Reply #9 on: 26 May 2019, 17:31:49 »
Ft, with a blob of loctite
Hoof'land storeman.
polilara
  • Finland
« Reply #10 on: 26 May 2019, 17:45:17 »
Sorry but what means Ft?
biggriffin
« Reply #11 on: 26 May 2019, 20:10:25 »
Foooking tight.
Hoof'land storeman.
polilara
  • Finland
« Reply #12 on: 27 May 2019, 07:24:45 »
OK, nice to learn new things.
ronnyd
  • Online Online
« Reply #13 on: 27 May 2019, 16:24:16 »
OK, nice to learn new swear words ;)
FTFY
Page created in 0.199 seconds with 21 queries.
