Author Topic: Rear Brake Pads pins and rattle springs  (Read 4950 times)
grifter
  • Paisley, Scotland
    • Omega 2.6 CD / Elite 3.2
« on: 26 May 2019, 19:20:08 »
Anyone know if the springs and pins come with the brake pad kits? I've got a mechanic friend getting me rear discs and pads at discount out of local factor, I think it's Apec pads/discs. I already bought a delphi pack of springs and pins in anticipation of them not being in thhe brake pack, but they are for the solid disc by the look of it, pins too short and rattle springs too small.
Might just buy a set to be safe rather than sorry. Do these look correct ones?
https://www.ebay.co.uk/itm/1x-OE-Quality-Replacement-Apec-Braking-Accessory-Kit-for-Brake-Pads-APEKIT315/311324684531?fits=Car+Make%3AVauxhall%7CModel%3AOmega&epid=1946937398&hash=item487c65b0f3:g:Va8AAOSwNSxVEYCl
It says listed for a 2.6 up to 2003 but they delphi pack I bought listed them as for this model but they obviously weren't. What a pain in the tits these springs and pins are!
polilara
  • Finland
    • 2.6 Y26SE Elegance 2001
Re: Rear Brake Pads pins and rattle springs
« Reply #1 on: 26 May 2019, 19:27:08 »
Air cooled or not?
grifter
  • Paisley, Scotland
« Reply #2 on: 26 May 2019, 19:30:15 »
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #3 on: 26 May 2019, 19:56:38 »
ask the seller to measure a pin
probably not the correct ones for vented discs 2.6 & 3.2
the ebay compatibility chart is clearly wrong
also worth checking that the ones you have fitted are ok,they might be fine
biggriffin
  • huntingdon, Hoof'land
    • Vectra in a posh frock.
« Reply #4 on: 26 May 2019, 20:06:33 »
I will bet the pins are for non-vented.
Just sold nice shiney new set..
Hoof'land storeman.
grifter
  • Paisley, Scotland
« Reply #5 on: 26 May 2019, 21:25:15 »
Thinking of reusing pins, it's mainly the rattle springs I need, mine are shot.
polilara
  • Finland
« Reply #6 on: 27 May 2019, 06:58:19 »
https://www.omegaowners.com/forum/index.php?topic=127928.0
Rattle spring is also different in vented/not vented.
grifter
  • Paisley, Scotland
« Reply #7 on: 27 May 2019, 19:30:06 »
Aye, it's defo bigger comparing the kit I originally bought with my old one.
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
« Reply #8 on: 28 May 2019, 18:19:39 »
Pins usually re useable unless realy bad and Spring usually just breaks its rivet so repairable too!
Yours may be worse however ? .
The fitment charts are rarely correct and harder to find the correct ones
« Reply #9 on: 03 June 2019, 22:08:06 »
I sometimes wonder why people made the guides...
Clearly visible on the index page ::)
Enceladus
  • London
« Reply #10 on: 04 June 2019, 14:57:01 »
That guide contains duff information. It needs to be corrected.
The GM part numbers referenced and the photo are all correct. However:
APEC KIT315 contains 74mm pins / 48mm cross springs and is for 12mm solid discs. Not for 20mm vented as implied in the guide.
APEC KIT310 contains 63mm pins and is not for a Vauxhall Omega B/B2 of any description.
Mintex MBA 1271 kit contains 74mm pins / 48mm cross springs and is for 12mm solid discs. Not for 20mm vented as implied in the guide.
Mintex MBA 1266 kit contains 63mm pins is is not for a Vauxhall Omega B/B2 of any description. Seems to be for some Astra F & Saab 9-3
The mistake for APEC seems to originate from the APEC catalogue for Vauxhall. KIT315 is stated to be for Omega vented rear discs. And KIT310 for solid. However the same mistake is not there for Opel. Only KIT315 is mentioned for Opel and nothing is listed for vented.
On the other hand the Mintex catalogue clearly states that MBA 1271 is for solid discs on Vauxhall/Opel and nothing is listed for vented at all. Kit MBA 1266 is not listed as being used on any Omega B.
I don't know of any 3rd party fitting kits that actually fit vented rears. And GM never sold the vented parts as a kit or supplied them with the pads. Only the sold disc kit came with the pads. The vented parts don't seem to have been used on any other Opel/Vauxhall/Cadillac etc. I suspect that there might be something suitable from an older BMW or Merc, Autovaux were apparently able to get alternatives from somewhere but that was several years ago.
New GM 56mm cross springs for vented are no longer available anywhere, including the USA probably, since around 2013. That said I've been told that 86mm pins could still be had a couple of years ago, so it's worth a shot to see can a dealer get some on special order.
The bottom line is that you need to clean and repair the vented pins and cross-springs if at all possible. One of the German forums recommends adapting a round nail to substitute for a pin.
« Last Edit: 04 June 2019, 14:59:29 by Enceladus »
raywilb
  • york
    • DS DS4
« Reply #11 on: 04 June 2019, 16:45:36 »
europarts 107721088 thats the order No. not long since did mine.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #12 on: 04 June 2019, 21:05:45 »
euro car parts
and those "107721088" won't fit 2.6 despite the website saying they will, or 3.2
they are for solid rear discs  ;)
2.6 and 3.2 are vented rear disc
raywilb
  • york
    • DS DS4
« Reply #13 on: 05 June 2019, 01:15:28 »
euro car parts
that number is for the vented discs, defo
biggriffin
« Reply #14 on: 05 June 2019, 09:58:38 »
euro car parts
Ecp DID do the pins for vented kits, weather you get the correct ones is another matter, your best going to your local store order them, and collect in person.
Hoof'land storeman.
Page created in 0.035 seconds with 21 queries.
