Author Topic: Ghanging alternator belt on Rover Steetwise  (Read 2657 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« on: 29 May 2019, 09:22:45 »
Last week MOT tester pointed out the alternator belt was in a bad state. Yesterday I replaced it with new, tricky job, because of little space between RH bottom of engine and body. I imagine on original assembly the engine is dropped in fully assembled, with little thought for belt changes in 15 years time. I suppose other front wheel drive cars are similar.
    • 2 Fords
Re: Ghanging alternator belt on Rover Steetwise
« Reply #1 on: 29 May 2019, 10:06:57 »
It makes life easier on many FWD cars to remove the wheel arch liner to improve access to the belts and pulleys.  :y
Migv6 le Frog Fan
  • Webs End.
  • Nicole's Papa
    • 3.2 Elite. Boxster. C1.
« Reply #2 on: 29 May 2019, 10:17:58 »
Yes, which is also why the crank sensor is routed in the self destructive way that it is.  :y
Women are like an AR35. lovely things, but nobody really understands how they work.
Viral_Jim
  • Telford
    • Too many, mostly broken
« Reply #3 on: 29 May 2019, 10:20:53 »
I've only ever done this job on one transverse engined car - jaguar x-type V6. As far as I can work out, the easiest method involves using a well trained ambidextrous spider monkey to thread the belt for you.
Or at least to not have hands like shovels.  ::)
« Reply #4 on: 29 May 2019, 17:48:17 »
Assuming the same as the Rover 25 - it will be - changing the aux belt is pretty easy and straightforward.  There is decent space between the engine and the inner wing :)
dave the builder
  • Online Online
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #5 on: 29 May 2019, 18:07:34 »
Unlike your pride and joy Zafira
if you have to do that aux belt, I can email you a list of swear words you will need  ;D
« Reply #6 on: 29 May 2019, 18:11:33 »
I looked at changing it once.  Came to the conclusion of "nah, f'it, its only the shitbox zafira", and never looked again ;D
terry paget
    • 3 Astras 2 Vectra
« Reply #7 on: 29 May 2019, 22:13:48 »
Did you manage to lock the tension pulley in the release position? I never did. I suspect, like on the Astra cam belt change job, it is necessary. or at least very desirable.
  • Chatham, Kent
  • Rover Metro 1.8VVC
    • 3.0l Elite estate
« Reply #8 on: 29 May 2019, 22:32:58 »
This. Quick easy job, even on a MGF.
terry paget
    • 3 Astras 2 Vectra
« Reply #9 on: 29 May 2019, 23:15:52 »
That's told me.
My other problem was, even with the tensioner pulley fully retracted, I struggled to get the new belt on the pulleys. I had this once before with an Omega auxiliary belt, I swear it was too short, and I never used it in the end. I know belts stretch, but there is not that much slack with sprung tensioners.
  • Chatham, Kent
    • 3.0l Elite estate
« Reply #10 on: 29 May 2019, 23:28:54 »
That's told me.
Are you using a long spanner or ratchet on them? That usually gives plenty of slack to get the belt on, which is tricky with standard length tools. The other thing to do is to fit the belt to all the ribbed pulleys first, and slip the back face onto the smooth tensioner. This requires less movement, and saves the need for an octopus.
« Reply #11 on: 29 May 2019, 23:45:15 »
Try it on SWMBO's Citroen C3 (BMW Mini engine apparently  :-\) The belt only drives the water pump part time and you need to disengage the drive to the belt ...... I didn't  :-[
Citroen did the job for me after I'd oppsed it up ...... £300 something IIRC
How hard can it be to change a 'fan belt'?
« Reply #12 on: 30 May 2019, 13:04:58 »
These 2 tips are exactly what I would recommend.
terry paget
    • 3 Astras 2 Vectra
« Reply #13 on: 30 May 2019, 13:43:34 »
That's told me.
Thanks Nick, several good tips there. I removed the outer (power steering) belt easily, locking the tensioner with a pin through the hexagon. It was trickier rotating the alternator belt hexagon, with a long spanner things got in the way, and a short spanner lacked the leverage.
 Haynes does a wonderful job explaining things concisely,  ' To hold the tension pulley in this position, fit a locking pin (max 3mm diameter) into the hole in the backplate, against the stop on the tension pulley.'He adds drawing 5.50 to clarify things, but in vain. Holding the ratchet with one hand I could not see where to insert my pin.
Next time it will be easier. I imagine Astras are similar.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #14 on: 30 May 2019, 16:45:43 »
Water pump runs off the back of the serpentine belt,there is a little plastic toggle to pull to release the tension from the water pump,easy then ::)
other rides
  mk3 Volvo v70 2.0 Diesel ,Citroen C2, Pug 306 cabriolet
Page created in 0.029 seconds with 21 queries.
