Author Topic: Fuel problem  (Read 267 times)
gbh
  • forest of dean
    • omega cdx 2.6
Fuel problem
« on: 30 May 2019, 12:51:50 »
Hi everyone,just returned from holiday and the car wouldn't start seemed like a fuel issue and sure enough I could see petrol dripping on to the floor.Just had a look this morning and when turning car over it seems to be leaking next to the fuel filter there is a join/coupling with a blue pipe and it looks like a green O ring has split or come out.So how to get it apart and where to get a replacement/part nos.Any help much appreciated!!!!! 2.6 saloon
gbh
  • forest of dean
    • omega cdx 2.6
Re: Fuel problem
« Reply #1 on: 30 May 2019, 13:40:52 »
Had some lunch and another look and it's the fuel filter has split somehow and fairly gushing out under pressure.It's a Mann one in case anyone is interested and can't see a reason.Any recommended ones and should I replace the clips as well?
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Fuel problem
« Reply #2 on: 30 May 2019, 14:17:10 »
most filters come with the plastic clips that go into the hoses either side
the green split ring is just plastic and not a seal IIRC
there is a special fuel line removal tool,(you need to squeeze the tabs both sides)
https://www.ebay.co.uk/itm/7-Car-Fuel-Line-Petrol-Clip-Pipe-Hose-Connector-Quick-Release-Removal-Pliers-UK/123347383556?epid=7023326285&hash=item1cb813b504:g:bz0AAOSwbTtbhj9f
you can get away without them but it makes the job much less of a faf
the filters do split and rust if old ,something that many people ignore when doing a service
gbh
  • forest of dean
    • omega cdx 2.6
Re: Fuel problem
« Reply #3 on: 30 May 2019, 14:33:30 »
Many thanks!!!!
gbh
  • forest of dean
    • omega cdx 2.6
Re: Fuel problem
« Reply #4 on: 30 May 2019, 14:35:03 »
GM or other???
Diamond Black Geezer
  • N E Lincolnshire
    • & a silly coupe coming...
Re: Fuel problem
« Reply #5 on: 30 May 2019, 15:08:01 »
I've gone GM, as it goes, however I'm fairly sure other makes would be fine. And certainly the likes of Mann are a top quality make, so wouldnt have any hesitation fitting another one of them, if I found one cheap.
Double check with Keith ABS if he has any kicking around.   :)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Fuel problem
« Reply #6 on: 30 May 2019, 15:09:53 »
GM or other???
GM or other what ?
fuel filter ?
your local car parts factor will supply one
you could possibly even get it from halfords or the like , but they tend to be expensive
Keith ABS
  • Maldon Essex
Re: Fuel problem
« Reply #7 on: 30 May 2019, 16:57:31 »
 I have just one on the shelf, GM I believe with clips
polilara
  • Finland
    • 2.6 Y26SE Elegance 2001
Re: Fuel problem
« Reply #8 on: 31 May 2019, 12:45:27 »
Yes, like what I had, never changed it until it was so bad corroded and started to leak.
biggriffin
  • huntingdon, Hoof'land
    • Vectra in a posh frock.
Re: Fuel problem
« Reply #9 on: 31 May 2019, 19:44:50 »
Halfords filter comes with clips.
Hoof'land storeman..
Rwd-less..
  • Millennium Man
    • The missus mad
Re: Fuel problem
« Reply #10 on: 01 June 2019, 08:59:57 »
I tend to use GM, based on the fact they are cheap (on TC) and delivered for free.  GM ones don't come with any clips, and as the clips become brittle with age, I always ensure I have a spare set just in case.  Although I've only ever broken a couple.
I don't tolerate bickering, and I'm always grumpy.
And Lizzie Zoom says I'm a heartless bastid...and she's absolutely correct!
Page created in 0.112 seconds with 22 queries.
