Author Topic: Renault Scenic Intermittent Starting Problem  (Read 486 times)
amazonian
  • upper beeding. west sussex
    • 03 2.2 CDX auto estate
« on: 16 June 2019, 14:06:32 »
Greetings all,
I have a Renault Scenic 2005 1.6 16V.  Automatic Petrol.  Yes, I know...
Anyway after a very long trip to France we started having problems whereby the car would turn over and not start.  Thinking it might be the alternator I took it into local mechanics who checked alt & battery and found no problems.  On doing a diagnostic they got 'an error message about the starter motor' which they found weird considering it has started perfectly for both me and them that morning several times.
Then they couldn't start it so they plugged it in again and got 'a couple more messages about the timing belt or the cam belt' and said I would need to take it to a main dealer.  Which for obvious reasons I would rather avoid doing...
So in summary the car will always start when cold.  Then say half an hour later after a drop off it will start again and then it will start again a few mins later.  However on about the 4th or 5th try it won't start and you have to wait for it to get 'cold' again before it will start.
Other symptoms are
-The dashboard lights are now dimming when we manually turn the lights on.
-When idling the 'range' mileage (ie what's left in the tank) display shows the mileage gradually dropping and then it will climb again once we start driving again
-The lights don't always come on by themselves any more when they always used to (in tunnels, etc)
When the starting issue happens the car turns over and sort of judders and bumps but won't start.  There are no error messages on the dash, either.
So if we can rule out the battery, alternator and possibly the starter motor, we can also rule out the cam belt (I should hope) as this was only re-done less than 2 yrs (10k miles) ago.
Browsing on google I have seen some suggestions saying it might be a faulty sensor etc, and I have no idea about the timing belt? So does anyone have an inkling as to what might be the problem?
Sorry for the long post and TIA for any help!
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
Re: Renault Scenic Intermittent Starting Problem
« Reply #1 on: 16 June 2019, 14:32:32 »
If it,s when warm that the problem is worse could it be some sensor issue? They tend to throw up other weird issues too. I,m sure someone with far more knowledge than me will be along soon. Oh, and it,s French. ;)
henryd
  • Moaning Haddock Head
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #2 on: 16 June 2019, 15:17:14 »
Crank sensor would be my choice,oddly Renault describe it as "vehicle speed sensor" just to throw you off track ::)
other rides
  Saab 9-5 Aero HOT estate,Focus 1.6 mk2,Pug 306 cabriolet
  • Up North
    • Astra 2.0 diesel
« Reply #3 on: 16 June 2019, 15:47:30 »
Ignore the 'range' issue. It will drop while stationary because it's trying to tell you how far you will get if you sit with the engine ticking over for ever. Not far.  ;D
If you are offended by anything I post, sorry. Just thought I'd get that in now.
« Reply #4 on: 16 June 2019, 16:48:17 »
This was my first thought as well.
Battery voltage and condition is also going to cause problems is it's starting to go flat from trying to start the car as the ecus and sensors are quite sensitive to voltage drops ;)
amazonian
« Reply #5 on: 16 June 2019, 17:18:31 »
Thanks fellas,
 Would;nt a crank sensor also cause misfiring and rough running though, or not  always ?
Seems to run well enough when its going,  I suppose the idea of it being the starter motor can be discounted,  and the   'timing belt'  code could also really mean crankshaft sensor fault.
Whats a ballpark figure for supply and fit a sensor,, or is it an easy diy job?
henryd
  • west cornwall
« Reply #6 on: 16 June 2019, 17:42:20 »
Thanks fellas,
Normally pretty easy on the 1600 16v engine,where gearbox joins the engine,two bolt fixing roughly top centre of joint
other rides
amazonian
« Reply #7 on: 16 June 2019, 21:55:48 »
Well, it may be worth just getting a new crank sensor and trying diy route then if its that simple to do.
Doctor Gollum,  The battery seems to have plenty of life in it !
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #8 on: 17 June 2019, 09:24:33 »
I think you will find that the fault can be traced all the way back to when you decided to purchase a French car :D
ronnyd
« Reply #9 on: 17 June 2019, 20:16:34 »
Serves him right really then. :-*
  • Up North
    • Astra 2.0 diesel
« Reply #10 on: 17 June 2019, 20:30:56 »
Yeah, it only lasted 14 years before playing up.
ronnyd
« Reply #11 on: 17 June 2019, 20:47:20 »
The delights of having a French car, if only for one day, are seared on my memory.  ;D
amazonian
« Reply #12 on: 02 July 2019, 22:05:11 »
Many thanks to to those who gave a possible diagnosis for the problem outlined in this post,  you were spot on and the crank shaft was changed and now all is well.
Thank you all very much.   (clicked on smiley things,  but they don't work)
ronnyd
« Reply #13 on: 02 July 2019, 22:19:45 »
Do you mean crankshaft sensor or the whole shaft?  :o
  • Chatham, Kent
  • Rover Metro 1.8VVC
    • 3.0l Elite estate
« Reply #14 on: 02 July 2019, 23:18:34 »
it was a Citroen, not a Mitsubishi.
Page created in 0.203 seconds with 22 queries.
