Pages: 1 [2] 3 4 5 6 7   Go Down
Author Topic: Car wont start after sitting for 3 years  (Read 14285 times)
Matteomart
  • Essex
    • Omega
Re: Car wont start after sitting for 3 years
« Reply #15 on: 23 June 2019, 13:32:08 »
Is it possible that the sensor near the rear view mirror has broken? I have a sun roof so maybe a bit of water has come through, there doesn't seem to be any water marks
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #16 on: 23 June 2019, 13:37:46 »
is the car battery ok ?
tried fob sync procedure ?
you could remove the -ve battery terminal for 10 mins to reset ecu ,then try a re-sync
hold the button on remote for about 10 secs aimed at sensor with key i on ?
Matteomart
  • Essex
    • Omega
« Reply #17 on: 23 June 2019, 13:42:42 »
I've done all of this a couple of times and nothing has worked, I'm really lost
Matteomart
  • Essex
    • Omega
« Reply #18 on: 23 June 2019, 13:44:08 »
I read that if it's an immobiliser issue the emo should flash when I'm cranking it, that doesn't happen the light goes off while the car is cranking
MonzaGSE
  • Norway
    • 95 Opel Omega mv6
« Reply #19 on: 23 June 2019, 13:45:29 »
Resync procedure for the old type ir remote is:
-separate remote from key
-turn key in ignotion (cant remember if its to position 1 or 2, try both)
-hold the remote maximum 5 cm away from the little dome sensor in the roof and press button on remote.
If resync is succesfull interior light will flash on/off a couple of times as confirmation.
Matteomart
  • Essex
    • Omega
« Reply #20 on: 23 June 2019, 13:59:35 »
Just tried this and still nothing, when I have the key in position 1 there isn't any lights could that be part of the issue? Position 2 I get dash lights
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #21 on: 23 June 2019, 14:16:10 »
Immobilizer
is the ID40 chip in the key ?
+1 for Immobiliser
BUT
the fob flashes but nothing happens to the car (it's the one that has a key and a separate fob)
The earliest cars didn't have a chip in the key. They used an infra-red transmitter in a separate fob that you had to point at a bulb up by the rear view mirror. Once you had disabled the immobiliser you had about a minute to start the engine before it immobilised again.
My first Omega (1994 L reg IIRC) had it. I think they only used that system for the first 2 years.
They had a Chip in the Key, as far as Im aware all UK Omegas had Chip + Transponder set up's, the Infra Red was purely for Remote Locking and Alarm.
Sounds to me like it could be a Crank Sensor issue, is the Immobilizer Lamp flashing when you Try and start the car?
It could be its still in "wont Start Immobilizer Mode", you could try Diss the Battery (Full Charged), fully remove the Main ECU and leave over night, put ECU back in Connect Battery (or other way around cant remember) if need be enter the Car using Key only and try a start and or re diagnose from there..
« Last Edit: 23 June 2019, 14:18:07 by zirk »
Matteomart
  • Essex
    • Omega
« Reply #22 on: 23 June 2019, 14:56:51 »
Immobilizer
+1 for Immobiliser
BUT
Is it possible the crank sensor is faulty and doesn't put out a code through the paperclip thing?
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #23 on: 23 June 2019, 15:39:18 »
you can get a weak crank sensor signal that will not throw a code
plus
you can't rule out parts like the fuel pump relay ,pump etc etc that you replaced (sometimes new parts are duff)
but until you sort the remote to lock and unlock the doors, you have to assume the car is immobilized
I take it there has never been an aftermarket alarm /immobilizer  ?
Matteomart
  • Essex
    • Omega
« Reply #24 on: 23 June 2019, 15:53:51 »
plus
I don't think there is any aftermarket alarm or immobilizer on it. I put a multimeter on the crankshaft sensor and between 2 of the pins i was starting at 10k ohms and if i kept the probes on the pins the resistance would slowly go up, I held it on long enough for it to get to 20k. Is that a faulty sensor or me doing something wrong?
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #25 on: 23 June 2019, 16:07:50 »
that is not how you test a crank sensor  :o   :-X
so start there  ;)
« Reply #26 on: 23 June 2019, 16:27:42 »
Faulty Crank sensor would still allow it to crank.  :-X
Matteomart
  • Essex
    • Omega
« Reply #27 on: 23 June 2019, 16:29:09 »
The car still cranks, Just no fuel pump or spark
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #28 on: 23 June 2019, 17:38:58 »
being the early Omega
does it have the fuel pump relay with the diode and 2 coils (as per omega A) ?
that takes a negative pulse from crank sensor to trigger firing
so if you have a duff one, you could loose spark and fuel IIRC
BUT
still think you need to resolve this non working remote fob / immobilizer
Matteomart
  • Essex
    • Omega
« Reply #29 on: 23 June 2019, 18:42:46 »
BUT
With the omega if you weren't using the fob to lock it you couldn't use your car with just the key?
Pages: 1 [2] 3 4 5 6 7   Go Up
Page created in 0.028 seconds with 21 queries.
