Author Topic: Fog light installation for opel omega facelift (2001)  (Read 1999 times)
Zrlizz
  • Norway
    • Opel omega b2 2.2 dti 16v
Hey!
Im trying to install foglights for my opel omega facelift (2001), i have the assemblies and the switch. But i cant find any wires for connevting the lights. Is there any?
Thanks
Re: Fog light installation for opel omega facelift (2001)
« Reply #1 on: 26 June 2019, 09:12:59 »
Left hand front wheel arch where the horn plugs in. Fog light switch can simply be swapped out once you have the main light switch out.
All in, it takes about 45 minutes to do if you pop the bumper off :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #2 on: 26 June 2019, 17:53:07 »
Relay?  :-\
« Reply #3 on: 26 June 2019, 19:08:14 »
Relay?  :-\
Already in place on my 2002 Desmond...
Zrlizz
  • Norway
« Reply #4 on: 26 June 2019, 21:02:53 »
Thanks for the answer!
When i took off the bumber off, right beside the horn, there was a cable zip tied and tucked away. Is this the one you mean? couldn't find anything more, looked on both sides to be sure. i tried connecting the loose cable i found to one of the light bulbs i have (hb4 bulb), do i even have the right bulb?  :-X
« Last Edit: 26 June 2019, 21:07:58 by Zrlizz »
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #5 on: 26 June 2019, 21:25:45 »
on my B2 (2003) V6 , the fogs share the same loom (and plug left wing) as the outside temp sensor
« Reply #6 on: 26 June 2019, 21:40:54 »
First you need the correct bumper loom.
Your car has a loom with two wires which goes to the external temperature sender at the centre of the bumper. Looks exactly like this...
https://www.ebay.co.uk/itm/Vauxhall-Omega-Z22XE-1999-2003-Air-Temperature-Sensor-Wiring-Loom-09146829-/332216064602
The other end goes to a four pin connector literally just above the horn.
Un plug this wire and discard it. Plug in the replacement bumper loom with four wires.
This should have two plugs for the fog lights and another plug for the temperature sensor.
I originally presumed that you had the fog lights and the wiring loom. If you haven't got the loom then someone here might sell you one if you ask nicely.
Also make sure that you have the correct lamps as the ones from 2001-2004 are different to 1993-2000. ;)
« Reply #7 on: 26 June 2019, 21:43:36 »
All facelift Omegas have the wiring to the plug. Only cars built with fog lights have the four wire bumper loom, base models only have the temperature sensor wires but the plug (and body loom)   are the same ;)
Zrlizz
  • Norway
« Reply #8 on: 26 June 2019, 22:16:16 »
Ohhh okey, thanks for the answer!
i have the right lamps, i made sure of that  :P
All i need to do now is to somehow get that bumper loom :P
do you know where to get it? i cant post in the trading forums yet :o can also be expensive for someone here to send it to norway? :/
« Last Edit: 26 June 2019, 22:22:51 by Zrlizz »
Zrlizz
  • Norway
« Reply #9 on: 26 June 2019, 23:10:27 »
i have now bought the bumper loom! :D
« Reply #10 on: 27 June 2019, 00:06:24 »
Excellent  :y
Page created in 0.051 seconds with 21 queries.
