Author Topic: Lpg not working.  (Read 9666 times)
Duke01
  • Southampton
    • 03 3.2 Elite Lpg
Lpg not working.
« on: 11 July 2019, 19:10:18 »
Hi guys,
3.2 , Just recently, i found the car will cut out and not restart on Lpg, but runs like a dream on petrol.
Starts fine then cuts when the Lpg kicks in, so am just using petrol at the moment.
Any Ideas?
Re: Lpg not working.
« Reply #1 on: 11 July 2019, 19:13:36 »
Both solenoid valves working?
Duke01
  • Southampton
    • 03 3.2 Elite Lpg
« Reply #2 on: 11 July 2019, 20:01:06 »
To be honest I dont know where to look for those..
« Reply #3 on: 11 July 2019, 20:23:28 »
One on the feed from the tank and one on the vapouriser :y aka shut off valves :y
Duke01
  • Southampton
    • 03 3.2 Elite Lpg
« Reply #4 on: 17 July 2019, 20:02:38 »
Ok, so, have had a play, the valve in the tank clicks over and so does the one under the bonnet.
On the second go she ran on Lpg, but misfiring, throwing a 0301.
It wont switch back on to petrol unless i clear the code first, then it does and runs perfectly on petrol.
Switch back to Lpg and its instant 0301.
The pipes look ok, is it the valve for that cylinder?
Puzzled.
« Reply #5 on: 17 July 2019, 20:55:29 »
Either plug or coil pack ;)
Duke01
  • Southampton
    • 03 3.2 Elite Lpg
« Reply #6 on: 17 July 2019, 21:14:22 »
I thought that, but runs perfectly on petrol, and i did coils (Bosch) about 25,000 ago.
I will pull the plugs again.
I cant understand it.
« Reply #7 on: 17 July 2019, 21:17:00 »
Lpg is sensitive to weak plugs ;)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #8 on: 17 July 2019, 21:19:13 »
LPG injector surely
« Reply #9 on: 17 July 2019, 21:27:39 »
LPG injector surely
No harm in swapping it with the one on cylinder 2 and see if the fault moves banks... :-\
Duke01
  • Southampton
    • 03 3.2 Elite Lpg
« Reply #10 on: 17 July 2019, 21:28:10 »
Ah ok,
Will try plugs, then injector. Thats a good point.
Have spares due to buying 8 at a time!  >:(
« Reply #11 on: 18 July 2019, 09:46:43 »
LPG injector surely
I'd be metering out the lpg loom first ;)
Duke01
  • Southampton
    • 03 3.2 Elite Lpg
« Reply #12 on: 18 July 2019, 21:36:56 »
Will google that,
My metering skills go as far as battery and alternator testing.
« Reply #13 on: 18 July 2019, 21:44:50 »
Does it drive? 🤔
Am down your way for the weekend, might be around Sunday afternoon if you can get it to Lyndhurst...
Duke01
  • Southampton
    • 03 3.2 Elite Lpg
« Reply #14 on: 19 July 2019, 18:47:06 »
It does drive.
Unfortunatley, Im away all weekend, but i do appreciate the offer. :y
Page created in 0.029 seconds with 20 queries.
