Author Topic: Electrickery escaping.  (Read 331 times)
Migv6 le Frog Fan
  • Webs End.
    • 3.2 Elite & French Hatch
« on: 17 July 2019, 12:56:16 »
Every once in a while, after the car has been parked for around a week, I go to start it and find the battery as flat as a witches mammary gland.
I drove it last Friday and was going to drive it again yesterday evening, and although everything electrical lit up and worked ok, there wasn't quite enough grunt in the battery to turn the engine over.
Battery is newish and I would be surprised if its on the way out, but its possible I suppose.
Where to start to look for the source of electric leaking out of the car ?  :-\
Its not my strong point tbh. Not quite sure what is, but I know electrickery isn't.  :D
Wish I didn't know now, what I didn't know then.
Re: Electrickery escaping.
« Reply #1 on: 17 July 2019, 13:04:09 »
Check the current draw across the 6 fuses on top of the battery and report back  ;)
Migv6 le Frog Fan
  • Webs End.
« Reply #2 on: 17 July 2019, 13:10:40 »
Will do when I get time. Got to visit sons wedding venue today. Got his graduation tomorrow. Back to work Friday..... ::)
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« Reply #3 on: 17 July 2019, 14:42:47 »
Albs, you say that you are confident that your battery is ok, but it's quick and easy to get a "drop-test" done at a tyre/battery place to be sure. The test will show if there is enough cranking power and/or total capacity in the battery.
That way you will start from an informed position before chasing possibly non-existent current drains.
Ron.
Migv6 le Frog Fan
  • Webs End.
« Reply #4 on: 17 July 2019, 15:57:20 »
Good idea Ron. :y
« Reply #5 on: 17 July 2019, 17:51:37 »
Ron.
It's an Omega ::) there will be 3-4 amps escaping between the battery and the cabin fusebox. Finding them will be an interesting challenge for Albs night shifts ;)
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #6 on: 17 July 2019, 19:34:58 »
I may be wrong, (most probably am ;D), but i was once informed that a drop test can knacker an older battery. Is this possible?
  • Online Online
  • Up North
    • Astra 2.0 diesel
« Reply #7 on: 17 July 2019, 20:31:58 »
Move away from the electrical and audio help section, put down the keyboard and put your hands behind your head. We've got you surrounded.  ;D
If you are offended by anything I post, sorry. Just thought I'd get that in now.
  • Millennium Man
    • The missus mad
« Reply #8 on: 18 July 2019, 09:39:44 »
Once that type of battery has been allowed to go flat once, its oppsed. End of.
I don't tolerate bickering, and I'm always grumpy.
And Lizzie Zoom says I'm a heartless bastid...and she's absolutely correct!
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #9 on: 18 July 2019, 13:43:00 »
This, /\ /\, they may recharge and show correct Volts etc, but once allowed to go flat a few times whilst connected, they never recover to there designed potential.
Just pull the Neg Lead off the Battery if your going to leave the Car to stand for a while (Power Sounder needs to be Removed) or get a simple Battery Terminal Iscolater to do the same job.
    • 3.2 MV6 (LPG), Westfield
« Reply #10 on: 20 July 2019, 10:23:12 »
There's a maintenance guide for this. ;)
http://www.omegaowners.com/forum/index.php?topic=90619.0
Page created in 0.134 seconds with 22 queries.
