Author Topic: Bigger Horn? (Zafira)  (Read 8367 times)
« on: 03 August 2019, 22:07:08 »
I've always felt the Zafira's horn could do with upgrading, it's very weak little "peep" type sound. Not nearly aggressive enough, always found Omega one decent enough.
Had to avoid someone reversing up lane 2 of M6, on way back from Ireland  :o
I really wanted a better horn then!
Fit second hand Omega or anything else out there?
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Bigger Horn? (Zafira)
« Reply #1 on: 03 August 2019, 22:18:06 »
It's probably only got one horn, when what's needed is a matched  pair: one high, and one low tone. The best horns are a pair of  the traditional cast Lucas horns used from the 50s, as they're bloody loud before you clean and adjust them. Hard to find now and expensive when you do.
But more practically, a pair from any more modern car(like the Omega) is a good bet. One that matches your car's plug, then wire them in series.
« Reply #2 on: 03 August 2019, 22:23:17 »
Re-use plug from Zafira one grafted to Omega horn loom?
I have seen a few videos of train horns being fitted, but that maybe tad too much.  ;D
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« Reply #3 on: 03 August 2019, 23:17:07 »
Maserati Sprint air horns are really effective!  :y 8)
Ron.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #4 on: 04 August 2019, 00:48:52 »
Ive got a set of original Two Tones of a 70s RR Fire Engine tucked away in the Garage if youd feeling lucky, they are bloodly loud.  :)
« Reply #5 on: 04 August 2019, 01:53:43 »
If you feel you need a bigger horn Tunnie, Viagra is now available without prescription from pharmacies.  :)
« Reply #6 on: 04 August 2019, 08:48:55 »
That's the last thing he needs. He needs to put his "horn" away before he outgrows the Zafira and starts looking for a VW bus. ;D
« Reply #7 on: 04 August 2019, 09:14:13 »
 ;D ;D ;D
 ;D ;D ;D
« Reply #8 on: 04 August 2019, 09:14:50 »
Not sure they would fit   ;D
« Reply #9 on: 04 August 2019, 09:15:25 »
Ron.
Not sure MrsT would appreciate loss of boot for a compressor  :D
    • 530D M Sport, 330i Coupe
« Reply #10 on: 04 August 2019, 09:45:48 »
Doing the same job on Mrs VXL's Astra. Have the twin horns from an Omega and acquired the loom, just need to modify the pluggable loom end so it can be swapped back in the future.
Bigron
  • Witham, Essex
« Reply #11 on: 04 August 2019, 10:28:01 »
I can't see an advert for the Maserati Sprint horns - 2 trumpet shrill granny-scarers - but these 3 trumpet ones could be even louder!
https://www.ebay.co.uk/itm/Triple-Trumpet-Air-Horn-12-V-178dB-Car-Truck-RV-Train-Boat-Loud-Replacement/401409171844?_trksid=p2485497.m4902.l9144
Ron.
  • Online Online
« Reply #12 on: 04 August 2019, 11:31:00 »
I can recommend the Whelen Alpha with a 100w speaker as fitted to my white omega...
Properly noisy ;D
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #13 on: 04 August 2019, 11:45:33 »
I've got two options for you both in stock.
 Pair of horns from an Omega. £20 posted.or
 180db tgv train air horns. ;D
Hoof'land storeman.
« Reply #14 on: 04 August 2019, 12:31:51 »
Ron.
I've got a cheap set of Italian twin trumpet air horns on the Westfield. They certainly get the message across and have worked happily for 19 years and counting. ;D
