Author Topic: Bigger Horn? (Zafira)  (Read 641 times)
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
Re: Bigger Horn? (Zafira)
« Reply #15 on: 04 August 2019, 14:34:13 »
Can,t you just get a single air horn on top of a canister of compressed air? Then just stick it out of the window as and when required. :D
  • Online Online
« Reply #16 on: 04 August 2019, 14:49:46 »
Presumably it would need tethering to the vehicle in order to be MoT compliant...
ronnyd
« Reply #17 on: 04 August 2019, 15:09:52 »
Couple of cable ties should do it. ;)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #18 on: 04 August 2019, 15:13:40 »
I tend to use the brakes,steering or GO pedal rather than the horn ,
 I can't remember the last time I used the horn  :P ;D
    • R320 TDM850 SmartRoadster
« Reply #19 on: 05 August 2019, 08:14:37 »
I've always felt the Zafira's horn could do with upgrading, it's very weak little "peep" type sound.  ......
As a Zafira is basically an Astra underneath i'm surprised because the two Astra Gs I had both had twin tone horns like the Omega had. In fact I replace the pathetic parp horn on SWMBO's Citroen with a pair of horns from the Astra I broke.
You sure one of the original horns hasn't died?
Keith ABS
  • Maldon Essex
« Reply #20 on: 05 August 2019, 10:03:39 »
Depends what model Zaf it is. My "A" was mid range and had a single while the "B" is SRI and has twin.
My 2.5 diesel elite estate only had a single
    • Zafira Tourer x2 SRi & SE
« Reply #21 on: 05 August 2019, 10:53:54 »
It's a Tourer, so Zaf-C and SRi spec.  :)
Got a VW, Audi, Skoda or Seat? I have full Diagnostic software VCDS to read and program your car. Need something enabling? Perhaps full diagnostic? Drop me a PM. Can diagnose in Camberley or Osterley Area.
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
« Reply #22 on: 06 August 2019, 03:46:05 »
My 1975 T150V Triumph Trident had a very quiet horn & after a couple of near misses I replaced it with an air horn compressor (about 2/3 diameter of an oil filter cartridge & the same depth) a couple of air pipes & the horns. Disadvantage is the compressor took 0.5seconds to spin up but when it did everybody within a half mile radius heard you, so recommended if you want to be heard & noticed. :y :y :y
Page created in 0.131 seconds with 21 queries.
