Author Topic: Starting with a miss-fire, when left overnight  (Read 1129 times)
  • Online Online
Re: Starting with a miss-fire, when left overnight
« Reply #15 on: 12 August 2019, 12:56:45 »
Loom fault will either be the trigger wire between the ecu and the coil pack plug or a busted plug not fitting the coil pack correctly... Easily crushed when fitting the coil pack if not paying attention.  ;)
Coolant has more chance of being the radiator than the head... But if it's not hitting the floor, it is evaporating off. Don't ignore the header tank, cracks around the cap neck can look like moulding seams ;)
Hth :y
    • Zafira Tourer x2 SRi & SE
« Reply #16 on: 12 August 2019, 13:29:29 »
Was very careful refitting everything, ordered a replacement new cap. Fingers crossed itís that.
Got a VW, Audi, Skoda or Seat? I have full Diagnostic software VCDS to read and program your car. Need something enabling? Perhaps full diagnostic? Drop me a PM. Can diagnose in Camberley or Osterley Area.
  • Solihull
    • 3x 3.2 V6 Elite Saloons
« Reply #17 on: 12 August 2019, 18:58:16 »
Can you smell coolant when it's hot / cooling down? Had to replace radiators in a couple of Omegas I've had because of fine cracks at the very top of the n/s plastic shroud - as it gets worse you see it dripping by the drain plug that gives the impression that the drain plug is weeping.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #18 on: 12 August 2019, 19:09:08 »
you could rig up a simple pressure test rig with a foot pump and some hose clamps and hose  :-\
  • Chatham, Kent
  • Rover Metro 1.8VVC
    • 3.0l Elite estate
« Reply #19 on: 12 August 2019, 19:50:36 »
Get a mountain bike or motor bike inner tube, cut it opposite the valve and attach to the cooling system in place of the driver's side radiator hose. Pressurise to 1bar, and go for a long lunch. It should hold pressure for that long. You can check used radiators this way, although it's pointless when a new one is <£100
« Reply #20 on: 12 August 2019, 19:51:42 »
Yes! There is a general whiff of coolant when hot and as I get out of the car. Iíll have a look around that area, so you have to take plastic top trim off to see it?
Itís been pressure tested are Serekís = All good
  • Solihull
« Reply #21 on: 12 August 2019, 20:02:05 »
Yes trims off a decent torch, difficult to see clearly but may see traces / stains of dried up coolant in that area.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #22 on: 12 August 2019, 20:04:28 »
coolant is going somewhere , so not all good  :(
I was thinking remove and blank the small overflow/return at the expansion tank ,then that leaves a small bore pipe to attach pump too ,easy to get at
Eboy.com
  • Bring back the starting handle
    • The missus mad
« Reply #24 on: 13 August 2019, 19:59:46 »
Remove plenum (but keep its coolant lines in tack. Remove intake. Pressure cooling system to about 8psi. Visually look for leaks in valley, rad sides, coolant bottle, and block to head areas.
Misfire - jump in it tomorrow. Flow throttle to full kickdown, and crank - it shouldn't start. Crank for a good 5s, and repeat. Then start normally. Improvement? If so, replace injector.
I own a Zafira, I'm allowed to feel depressed.
« Reply #25 on: 13 August 2019, 21:15:32 »
Will try pedal start trick, in Wales until Sunday though in the Zafira.
I have no means to pressure test coolant system.  :(
  • Online Online
« Reply #26 on: 13 August 2019, 21:19:11 »
Do you own a bicycle pump?
  • Chatham, Kent
    • 3.0l Elite estate
« Reply #27 on: 14 August 2019, 01:15:09 »
that, a cheap bike inner tube and a couple of hose clamps.
Or a screw a replacement Schrader metal valve into a new(that doesn't leak) expansion cap and pressurise using your bike pump, less than 1bar is enough.
You could buy a test set, but you'll probably have to bodge an adapter so it's not worth the expense for the use you'll get.
« Reply #28 on: 14 August 2019, 12:25:51 »
I would have to buy all that, plus no time to do it.
Just realised though, Iíve not checked the passenger footwell yet to see if thatís wet.
  • Chatham, Kent
    • 3.0l Elite estate
« Reply #29 on: 14 August 2019, 12:54:12 »
Oh.
Back to guessing then.
Good luck
Pages: 1 [2] 3 4  All   Go Up
Page created in 0.162 seconds with 21 queries.
