Author Topic: 3.2 timing and belt tensoon  (Read 345 times)
gazzap
  • colchester essex
    • Omega Estate 2.6 MV6
« on: 24 August 2019, 17:32:20 »
evening everyone, hoping someone might be able to shed some light on this issue im having, i brought a timing kit from gates for my 3.2 v6, and found out there are 3 diff types, the type i have is the one with a short backplate and come's with 3 tensioner pully's, i would add pics but i have no idea how  :( the haynes manual only shows the tension sequence for the 2.5/3.0, does anyone know if the belt tension sequence (and amount of tension) is the same for all the kits? no matter the location of the idler pulley ? as mine is higher than the one in the Haynes book, hope that makes sense, cheers
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: 3.2 timing and belt tensoon
« Reply #1 on: 24 August 2019, 18:01:08 »
use the backplate from your cars 2 top idlers if your new one is different
setting up the belt is complex
you could just buy the DVD from the OOF webshop
do you have the timing belt locking kit ?
« Reply #2 on: 24 August 2019, 18:05:26 »
All of this :y
gazzap
  • colchester essex
« Reply #3 on: 24 August 2019, 18:22:02 »
i don't want to change it mate, as i need them for my 2.6, just want a guide on how to time and tension the short backplate kit with 3 tensioner pulleys on a 3.2 there must be some instructions, if not ill get a garage to do it, didn't know there was a dvd tho
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #4 on: 24 August 2019, 18:36:57 »
You will still need the timing kit as many who didn't bother have discovered. :y
« Last Edit: 24 August 2019, 18:40:09 by Shackeng »
gazzap
  • colchester essex
« Reply #5 on: 24 August 2019, 18:54:07 »
yeah mate ive got the kit  :y just need to know what the tension sequence is or if its the same as all the other engines with 3 tensioner pulleys ???
Jan Suhr
  • Nyköping, Sweden
    • 2 Omega Caravans 3.2 V6
« Reply #6 on: 24 August 2019, 19:11:02 »
When you buy the kit they usually ask for the engine number. That number says which kit you need.
Jan Suhr
Stockholm, Sweden
www.protouring.se
Yodel-Odel-a-Eboy.com
  • Bring back the starting handle
    • The missus mad
« Reply #7 on: 24 August 2019, 19:46:09 »
All kits have 2 idlers and 1 tensioner pulley.
All kits are interchangeable, as long as your swap the top idler and tensioner over to your old backplate.
Full instructions on how to fit belt are on the OOF V6 Cambelt DVD. Worth £3 + postage of anyones money ;)
I own a Zafira, I'm allowed to feel depressed.
biggriffin
  • Moaning Haddock Head
  • huntingdon, Hoof'land
    • Vectra in a posh frock.
« Reply #8 on: 25 August 2019, 16:21:48 »
  THIS^^^^^^^ :y
Hoof'land storeman.
Page created in 0.109 seconds with 22 queries.
