Author Topic: Reversing sensors stopped working.  (Read 502 times)
Migv6 le Frog Fan
  • Webs End.
  • Nicole's Papa
    • 3.2 Elite & Welsh Hatch
« on: 01 September 2019, 18:48:04 »
As above, don't even get the initial beep when put it in reverse. Where to start - do they have their own fuse near the rear somewhere ?
Plastic Welsh hatchbacks are awesome.
I would like to know what will happen this year, but I don't have 20 20 vision.
    • R320 TDM850 SmartRoadster
Re: Reversing sensors stopped working.
« Reply #1 on: 01 September 2019, 19:10:38 »
There's a guide somewhere that covers reversing sensors .....
Migv6 le Frog Fan
  • Webs End.
  • Nicole's Papa
« Reply #2 on: 01 September 2019, 19:14:01 »
Good point Andy. Its so long since I looked at them , I forgot about them.
Migv6 le Frog Fan
  • Webs End.
  • Nicole's Papa
« Reply #3 on: 01 September 2019, 19:18:30 »
Had a look and seems knackered speaker is the favourite. Might have a spare in the cave. Second possible option is no power to unit.
Get the multimeter out I suppose. Still don't know if theres a fuse for the power supply to it though.
« Reply #4 on: 01 September 2019, 19:27:46 »
Nige / Entwood is the guru on these  ;D You remove what looks like a fuse and something to do with counting beeps ...... I've  only had reverse/parking sensors since I had a 3 point star on my car  ::) ::)
« Reply #5 on: 01 September 2019, 20:50:01 »
A front door tweeter serves as a reliable replacement speaker :y
Counting the beeps only works if you can hear them...  ::)
As a basic system check, ignition to pos 2 engine off, pop it into reverse. Check the reversing lights work and gently Place a fingertip on each sensor in turn.
You should feel a 'buzz' from each sensor... No buzz, no worky :y
« Reply #6 on: 01 September 2019, 21:20:06 »
I wouldn't know  ::) My car has leds too  :P
Migv6 le Frog Fan
  • Webs End.
  • Nicole's Papa
« Reply #7 on: 02 September 2019, 19:09:41 »
So, Ive diagnosed a fooked speaker, which isn't a surprise. Connected up a speaker I have spare from a Bluetooth kit for test purposes and the beeps returned louder than ever. Much louder. Then tried connecting a front door tweeter, but the beeps were then so quiet they were almost inaudible. Istr RobG saying a long time ago the tweeter needs a mod - resistor added or removed ?
Must try and find it.
Also found some serious rust in the spare wheel well while I was in the area. Dug it out, treated it with rust killer for the moment. Got three holes there now, so the welder has to come out soon.
« Reply #8 on: 02 September 2019, 19:13:42 »
Non bose tweeter...  ::)
Deal with the sunroof drains and boot lid seal whilst you're at it ;)
Migv6 le Frog Fan
  • Webs End.
  • Nicole's Papa
« Reply #9 on: 02 September 2019, 19:30:50 »
You mean I need a non Bose tweeter ? Didn't realise that Bose tweeters were different, but I suppose they must be, like the other speakers are.
Don't think the issue is sunroof drains or boot seal Its always been dry in there in the time Ive owned the car. I think its had water in there in the past which has got into the seams and started the rot, which once established, just keeps going.
« Reply #10 on: 02 September 2019, 19:40:13 »
Xactly.
Fair enough, worth checking for evidence of damage from below too :y
In that order ;)
Page created in 0.159 seconds with 22 queries.
