Author Topic: Rear suspension adjustment arm  (Read 423 times)
Jsomega
  • Kent
    • Omega Estate dti 2.2
« on: 11 September 2019, 14:32:17 »
I am trying to locate a new rear suspension arm for offside or 2 , to replace, as can't be adjusted for tracking.  Anyone know where or if new ones are available?  Or will it have to be second hand? Have been searching but no joy so far.
Diamond Black Geezer
  • N E Lincolnshire & Coventry
    • & a silly coupe coming...
Re: Rear suspension adjustment arm
« Reply #1 on: 11 September 2019, 14:39:17 »
I think new ones can be about 100 each, so no smallfry, however they should last donkeys years - a lot longer than front on cars which are really a service item.
However used can be had, and as above, should last a good while. The main issue is you need heat to free them up, clean the threads etc to allow for adjustment. I assume this is your issue. If you're able remove, get round to a garage to warm them, grease them up and refit, it's the threads that tend to go through rust, rather than the balljoints.  :y
Jsomega
  • Kent
« Reply #2 on: 11 September 2019, 14:49:24 »
The mechanic has tried heating but no joy.  Can you suggest anywhere for new/used or is it just a question of searching?
« Reply #3 on: 11 September 2019, 16:10:56 »
German and US eBay, ideally with the part numbers :y three pieces to each arm, and they aren't sided :y
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #4 on: 11 September 2019, 16:53:47 »
I have 2 bought new a few years ago for just this eventuality, and No, I don't carry them in the car, 'just in case.' ::)
biggriffin
  • Moaning Haddock Head
  • huntingdon, Hoof'land
    • Vectra in a posh frock.
« Reply #5 on: 11 September 2019, 17:56:26 »
Get them red hot, crack lock nuts off,  then undo rods with a back and forth movement.
Hoof'land storeman.
Shackeng
  • Ramsbury
« Reply #6 on: 11 September 2019, 19:34:48 »
Once removed, and heated as above, it becomes easier.  :y
Jsomega
  • Kent
« Reply #7 on: 11 September 2019, 20:04:28 »
Will go and do some searching on non UK sites tonight and will pass on comments regarding trying to loosen, thanks everyone much appreciated?  I am not prepared to give up on my car as it has been so good and wear and tear happens to us all at some point!
Yodel-Odel-a-Eboy.com
  • Bring back the starting handle
    • The missus mad
« Reply #8 on: 12 September 2019, 12:58:58 »
I had to replace mine where they had seized, and the heat+adjustment with it on the car had deformed one of them.  I think I paid about 80 each, from a dealer.
I own a Zafira, I'm allowed to feel depressed.
Migv6 le Frog Fan
  • Online Online
  • Webs End.
  • Nicole's Papa
    • 3.2 Elite & Welsh Hatch
« Reply #9 on: 12 September 2019, 13:19:41 »
I bought a pair of Lemforder ones for 100 a couple of years ago. Cant  remember where from though, apart from it was online.
Plastic Welsh hatchbacks are awesome.
I would like to know what will happen this year, but I don't have 20 20 vision.
« Reply #11 on: 19 September 2019, 11:13:36 »
Not a bad price, given their projected lifespan.
Page created in 0.143 seconds with 22 queries.
