Author Topic: light warning comes on but lights seem ok  (Read 13225 times)
addy
  • County Durham.  UK
    • 2.6 CD Saloon 2ltr omega
« on: 28 September 2019, 19:22:12 »
Does anyone have any idea, why the tail headlight warning comes on? It is a 1995 Omega, checked the bulbs but cannot see anything obvious. It used to come on intermittently, I changed Headbulb and it hasn't done it for ages. Now it has done it twice.
Thanks for any help.
Drives 1995 2.0ltr CD Estate.  2002 2.6 CD saloon
MonzaGSE
  • Norway
    • 95 Opel Omega mv6
Re: light warning comes on but lights seem ok
« Reply #1 on: 28 September 2019, 19:31:38 »
I had this some years ago on a 1995 Omega. On mine the headlught/taillight warning would be on constant with the headlights turned on. Changed bulbs, cleaned connectors and checked wiring but could never figure it out. Finally i found some Opel/Vauxhall service manual for Omega B online which had a service bulletin stating that on some early cars when customer complained about headlight/taillight warning and all lights worked fine the solution was to swap the light warning module to a newer type. Early cars seemed to have a more unreliable warning module. Bought one of eBay and swapped it over. Problem went away for me and never came back.
addy
  • County Durham.  UK
« Reply #2 on: 28 September 2019, 19:35:37 »
Thank you for the quick reply. Sorry for appearing stupid but what and where is the light warning module on a 1995 Omega Estate? They are normal headlights, not HID and doesn't have self levelling suspension.
Addy
« Last Edit: 28 September 2019, 19:38:18 by addy »
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #3 on: 28 September 2019, 19:37:57 »
rear number-plate lights ok ?
any non canbus  LED lamps been fitted  ?
addy
  • County Durham.  UK
« Reply #4 on: 28 September 2019, 19:40:02 »
No Led lights, normal ones. I use the same bulbs in my 2002 Omega without any problems. Must admit never thought about the number plate lights, will check when wife gets back.
« Reply #5 on: 28 September 2019, 19:40:17 »
This :y
MonzaGSE
  • Norway
    • 95 Opel Omega mv6
« Reply #6 on: 28 September 2019, 19:46:49 »
Bulb control unit lives on the sidewall inside the dash where the a pillar meets the dashboard. Remove the cardboard under the dash driver side and its way up at the top above the fusebox clipped to the sidewall/a pillar. At least on lhd cars. Dont know about rhd cars but would assume it to be on driver side there to.
addy
  • County Durham.  UK
« Reply #7 on: 28 September 2019, 19:51:21 »
Thank you, will check No. Plate lights. If ok, will check the unit. I think I have found it on ebay, is this it?
https://www.ebay.ie/itm/Genuine-Opel-Vectra-B-Omega-B-Control-Unit-Sensor-Light-Bulb-Control-9135155-/222895537893?hash=item33e59bfee5
MonzaGSE
  • Norway
    • 95 Opel Omega mv6
« Reply #8 on: 28 September 2019, 20:08:34 »
Dont know that partnumber. Checked now and the part i bought for my 1995 estate is GM 90451202. Sedan might be GM 90460934.
MonzaGSE
  • Norway
    • 95 Opel Omega mv6
« Reply #9 on: 28 September 2019, 20:10:35 »
And used unit will probably do fine. Since the newer type seems very reliable.
addy
  • County Durham.  UK
« Reply #10 on: 29 September 2019, 14:09:07 »
Thanks everyone, you were correct one of the Number plate lights was loose, so was working until I tapped it, then it would go out, tap it again and it would work, so bent the connectors out slightly seems to be working.
« Reply #11 on: 30 September 2019, 19:46:50 »
numberplate lights aren't on check control on the Omega, so it aint that.
The saloons have 4 tail bulbs, 2 integrated into brake lights, 2 seperate. Ensure all 4 are secure. It can be fussy on really shit quality bulbs, like egay specials, or old school Halfords (but anything in last 5yrs seems fine)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #12 on: 30 September 2019, 20:03:56 »
tested by check control with the side/park lights ,they where on Carlton Omega A anyway
and repairing the number plate light has fixed the issue the OP had
  • Online Online
« Reply #13 on: 30 September 2019, 20:15:48 »
I'm glad you said that as I was sure my Omega's number plate wasn't covered  :y
addy
  • County Durham.  UK
« Reply #14 on: 01 October 2019, 09:01:35 »
You are correct. The message reappeared, so between the rain took each bulb out. Passenger side with the two elements in, was not looking to good, so changed it everything seems ok for no.
The number plate bulb, being lose was a red herring.
Thanks again for the help.
Addy
