Author Topic: OMEGA CD 3.0 TURBO  (Read 55381 times)
luizvivas
  • Belo Horizonte, MG, Brazil
  • 92/93 Toulon Green 1-5-3-6-2-4
    • Omega CD 3.0 Turbo
OMEGA CD 3.0 TURBO
« on: 08 October 2019, 15:39:35 »
Since the launch of Omega in Brazil in 1992, I have dreamed of this car. In 2004 I finally bought one of the first models manufactured. Unfortunately it was not treated well by the former owner. In 2009 I was forced to rectify the C30NE block and headstock and as I use more for travel and tours, the engine is currently only 25,000 km driven. Before Omega I had other cars, but one of them, VW Apollo, had the brave AP 1.8 engine, which I had to prepare with turbo. In March 2019 I finally did another project: my dream car with turbo. Below the key scenes of the process:
TURBO HOLSET HX-35, 50/63:
PANDOO PRO INJECT PROGRAMMABLE INJECTION:
DISPLACED BATTERY FOR CARRIER:
REPLACEMENT OF WATER PUMP AND 12 BLOCK STAMPS, NOW ALUMINUM, MADE TO MEASURE:
EXHAUST COLLECTOR PURCHASED ON THE "CUSTOM" INTERNET THAT NEEDED TO BE MADE TWICE:
WASTE GATE VALVE PIPE HAS BEEN REMOVED AFTER THIS PHOTO, LACK OF SPACE:
PRESSURIZATION PASSES UNDER ENGINE:
WATERCOOLER AND ITS COOLING SYSTEM:
IGNITION WITHOUT DISTRIBUTOR AND WITH 6 VW UP COILS:
C30NE TURBO:
PRO INJECT CENTER MOUNTED ON PANEL:
LAMBDA PROBE DISPLAY WIDE BAND FUELTECH:
ORIGINAL EXHAUST DAMS REPLACED:
NEW PAINT ENGINE COVER:
Engine, clutch, differential, transmission use original parts. Air conditioning, much needed in Brazil, was maintained. It is managed by the original injection, which works together with the Pandoo injection. The watercooler is very efficient. At low speeds, the intake air temperature reaches a maximum of 39 ° C, even on very hot days.
Internal fuel pump, 12 bar
65 lb / h injectors
Air filter K&N in box
1 bar pressure
300 HP
45 kgf
Fuel Ethanol
Powered by C30NE
Varche
  • middle of Andalucia
    • Golf Estate
Re: OMEGA CD 3.0 TURBO
« Reply #1 on: 08 October 2019, 17:34:45 »
Interesting project.  :y
Is it easy to get ethanol?
Migv6 le Frog Fan
  • Webs End.
  • Nicole's Papa
    • 3.2 Elite. Boxster. C1.
« Reply #2 on: 08 October 2019, 22:58:49 »
Looks like a superb project Luis. A lot of work and skill has gone into it.
Women are like an AR35. lovely things, but nobody really understands how they work.
DrAndyB
  • Neston / Cheshire
    • 2.5 V6 CDX Manual (MFL)
« Reply #3 on: 09 October 2019, 20:24:48 »
Nice  :y
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #4 on: 09 October 2019, 21:11:07 »
Excellent, how you going to control the boost now? internal wastegate I presume :y
Laying a rubber road.
luizvivas
« Reply #5 on: 09 October 2019, 21:17:57 »
Ethanol in Brazil you find in every gas station. Depending on the state costs between 30 and 40% less than gasoline. It's cost-effective, it cleans the engine inside, has more octane, you can use more turbo pressure and the engine runs cooler in the combustion chambers. Our regular gasoline has 27% mixed anhydrous alcohol, not recommended for pressure above 0.7 bar. Another option is premium gasoline, which costs twice as much as Ethanol. Long live the Ethanol, kkkkkkkkk!
The small reservoir with the brown cap at the top left of the photo is gasoline. Cold engine you press for 1 second a key on the panel (may be automatic system, but prefer the simple system), the start happens easily.
Powered by C30NE
Raeturbo
  • South Wales
« Reply #6 on: 09 October 2019, 21:23:19 »
Pity they didn’t sell it here for that price I’m running 1.7 bar on 99RON.
luizvivas
« Reply #7 on: 09 October 2019, 21:23:56 »
Unfortunately, wastgate lacked space, we were required to use pop off valve. Pictured above is near the upper left side of the radiator. You hear two sneezes. The pop off sneezes first.
Powered by C30NE
Raeturbo
  • South Wales
« Reply #8 on: 09 October 2019, 21:34:25 »
So spring strength dictates boost?
luizvivas
« Reply #9 on: 09 October 2019, 21:43:07 »
In my previous car, between the years 2000 and 2004, the first month, I tried to use regular gasoline at 0.8 and there was pre detonation. I switched to ethanol and used 1.8 bar. Some friends used between 2 and 2.5 bar without much problems, except the transmission gears, which broke kkkkkkkkk. Today this does not happen because there are good manufacturers of forged gears around here.
Powered by C30NE
luizvivas
« Reply #10 on: 09 October 2019, 21:45:01 »
Yes. Spring strength dictates boost.
Powered by C30NE
Raeturbo
  • South Wales
« Reply #11 on: 09 October 2019, 21:59:58 »
Just had to replace gearbox and transfer box on the Evo it ripped fourth gear apart 420+ bhp and 420+torque :-\
Raeturbo
  • South Wales
« Reply #12 on: 09 October 2019, 22:06:09 »
I had a manual Carlton 3.0 24V that color lasted until 260,000miles :y
Varche
    • Golf Estate
« Reply #13 on: 09 October 2019, 23:54:07 »
Just had a look at worldwide ethanol production.
USA top, then Brazil ( made from sugar cane), then European Union with around a sixth of that of Brazil . Never seen it on sale in Spain but maybe it is described as bio diesel in which case I have.
« Reply #14 on: 10 October 2019, 01:47:47 »
The EU version is probably closer to Vodka than sugar cane ;D
Pages: [1] 2 3 4  All   Go Up
