Author Topic: XENON headlight motors  (Read 5321 times)
Jan Suhr
  • Nyköping, Sweden
    • 2 Omega Caravans 3.2 V6
« on: 26 October 2019, 10:26:21 »
Is there a way to check the leveling motors for XENON-lights when the motors aren't in the car?
I have a few extra from cars I scrapped and I would like to check if they are good or not.
Thinking that I could connect them to 12+V and see if they move or not.
Thanks
Jan Suhr
Stockholm, Sweden
www.protouring.se
Re: XENON headlight motors
« Reply #1 on: 27 October 2019, 11:07:38 »
Hmmm, not sure without the ECU which sits up on the wheelarch.  Not sure if its a PWM control line, or a variable voltage.
I'll try to look at wiring diagram later.
Jan Suhr
  • Nyköping, Sweden
« Reply #2 on: 27 October 2019, 11:12:50 »
I had just taken one motor apart when you posted.
It looks like pin 2 and 4 goes to the motor. The other pins goes the switch in the motor that stops the motor from going to far.
I'll check and confirm later.
Thanks
Jan
Jan Suhr
Stockholm, Sweden
www.protouring.se
« Reply #3 on: 27 October 2019, 11:14:25 »
Ah, loos promising then :)
There should be some kind of feedback circuit as well, so the Headlight Levelling ECU would know the light's position.
Jan Suhr
  • Nyköping, Sweden
« Reply #4 on: 27 October 2019, 11:44:25 »
Ok I can confirm that pin 2 and 4 powers the motor. Switch Pos and Neg between them moves the adjuster in or out. Be careful to just give them a short push just to see that it moves. Using this method bypasses the built-in stop that prevent the motor from going to far in or out. Pin 1, 5 and 6 are for the stop at each end of the cycle and they report back to the ECU.
Jan Suhr
Stockholm, Sweden
www.protouring.se
« Reply #5 on: 27 October 2019, 11:51:33 »
Calling Jimbob to Leccy section. I think the above is worthy of making into a guide :)
Jan Suhr
  • Nyköping, Sweden
« Reply #6 on: 27 October 2019, 12:23:53 »
Jan Suhr
Stockholm, Sweden
www.protouring.se
