Author Topic: Front fog-lights on a non-fog-light car  (Read 2194 times)
ChrisPee
  • Kent
    • Omega Select estate
« on: 27 October 2019, 19:30:07 »
Hello people, I guess this has been covered previously but I couldn't see an answer anywhere.
I have a 97 Select estate which has a damaged front bumper, I've just bought a good s/h one with fogs in. The wiring is clipped to the front bumper bar on the car but there is no front fog light switch on the dash - only a blank next to the rear fog switch. If I fit a just fit a switch will they work?  :P
Thanks in advance.
  • Bring back the starting handle
    • The missus mad
Re: Front fog-lights on a non-fog-light car
« Reply #1 on: 27 October 2019, 19:49:05 »
When you fitted the bumper, was the loom there by the horn to plug the fogs into?
If so, its just the switch :)
I own a Zafira, I'm allowed to feel depressed.
« Reply #2 on: 27 October 2019, 19:56:36 »
Yup ;)
Also, the fog light switches can be removed from the main switch, and are physically the same regardless of front or rear, so you can swap the rear switch over to the blank switch to test. Which is nice :y
Re the loom, the temperature sensor wiring shares the fog light loom so should be plug and play :y
    • R320 TDM850 SmartRoadster
« Reply #3 on: 27 October 2019, 23:06:14 »
Is not a relay too?  :-\
« Reply #4 on: 28 October 2019, 01:04:47 »
Possibly, in which case it's another small black one in the panel under the steering column, but don't remember needing one when I added fogs to my GLS ;)
MonzaGSE
  • Norway
    • 95 Opel Omega mv6
« Reply #5 on: 28 October 2019, 07:09:35 »
A 97 car will probably have the telltale light which shows the fogs are on in the switch itself. Later ones had it in the instrument i think. Led which indicates fogs on are part of the circuit board on the main light switch. Also there are two types og fog switches. The old type with a clear square for the indication light and the new type without this. With fog switches renoved you should be able to see if there are leds on the circuit board on the main switch.
ChrisPee
  • Kent
« Reply #6 on: 28 October 2019, 17:59:32 »
I'm a bit confused by all this very helpful help, it has the wiring connectors at the front to plug straight in tothe lights, the rear fog switch has a clear window that lights up orange, and to the left of it is a blank. It doesn't look like there is any wiring behind the blank, but the suggestion to use the rear switch makes sense. I'll wire them up at the weekend and try this out. Thanks for all the reply-ers  :y :y
« Reply #7 on: 28 October 2019, 18:07:19 »
The slight confusion stems from the fact that it could be Pre or mid face-lift and one of the things they changed was the light switch.
At least if the loom is present then the odds are definitely in your favour  :y
ChrisPee
  • Kent
« Reply #8 on: 28 October 2019, 18:45:01 »
Thanks Doc.  :y
    • The missus mad
« Reply #9 on: 29 October 2019, 18:58:57 »
If the last *LETTER* of the VIN is a T or V, then a '97 car is PFL. If it W, then a 97 car is MFL.
biggriffin
  • huntingdon, Hoof'land
    • Vectra in a posh frock.
« Reply #10 on: 30 October 2019, 16:14:29 »
You will need either the switch, or complete headlight switch block, which I might have £10 delivered. ;)
Hoof'land storeman.
Raeturbo
  • South Wales
    • Mv6 3.2 Mitsi Evo2
« Reply #11 on: 07 December 2019, 22:35:40 »
I donít know who will agree with me on this but I find these fog lights absolutely useless, so if I was you I wouldnít bother 8)
Laying a rubber road.
    • The missus mad
« Reply #12 on: 08 December 2019, 19:43:17 »
They work quite well at illuminating the kerb/verge in heavy fog.
Obviously the world is full of 'tards who think they should have them on all the time, as the opps you I'm OK Jack attitude spreads :(
Raeturbo
  • South Wales
« Reply #13 on: 08 December 2019, 20:13:36 »
indeed thatís true
78bex
    • 2.2 CD AUTO / FAZER 600
« Reply #14 on: 30 December 2019, 23:51:52 »
agree ,  the other night I relied upon them to stay in touch with the nearside & kept running into pockets of mist/ fog behind the South Downs. Not helped by another car, that had latched onto me & was using me to light his way ahead  ;D
Page created in 0.126 seconds with 22 queries.
