Author Topic: what is the proper size spanner for brake line nuts  (Read 8608 times)
Enceladus
  • London
Re: what is the proper size spanner for brake line nuts
« Reply #15 on: 20 November 2019, 22:05:17 »
Part nr. GM 90297538. I'll see can I dig one out and and confirm, however I think they're the same as a Carlton or maybe a Senator, so should be M7 x 1.0 x 41mm. 9mm across the spanner flats.
That would be for solid disc caliper. Omega vented rears have a slightly larger piston, so I'm not sure if the bleed is exactly the same. I would imagine it is.
Enceladus
  • London
« Reply #16 on: 20 November 2019, 22:48:46 »
Update.
GM nr. 90297538 actually measures as M7 x 1.0 x 38.4mm. 9mm spanner flats.
« Last Edit: 20 November 2019, 22:50:24 by Enceladus »
addy
  • County Durham.  UK
    • 2.6 CD Saloon 2ltr omega
« Reply #17 on: 21 November 2019, 08:27:28 »
Thank you  Enceladus for the help. It is for a 1995 2ltr Omega, which has the solid discs. Can get some ordered.
Addy
Drives 1995 2.0ltr CD Estate.  2002 2.6 CD saloon
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #18 on: 21 November 2019, 13:54:21 »
Update.
standard part, doesn't have to be GM
