Pages: 1 2 [3]  All   Go Down
Author Topic: One for Fuse19....  (Read 734 times)
    • Zafira Tourer x2 SRi & SE
Re: One for Fuse19....
« Reply #30 on: 21 November 2019, 14:52:39 »
Anything I should look out for on the 1.4T?
Not on that derivative no, the later one is direct injection so a little more sensitive, the one you have is a larger version of the chain driven cam 1.2 used in Corsa etc plus variable valve timing and a few other bits.
Regular oil change is king on them, then they just work and last
Thanks  :y
Yes regular changes, to keep that chain lubricated.  :)
It's use will be 95% town, rarely going on high speed runs. Although when given chance I will take it on long runs, Wales for example at Christmas.
I plan yearly or 5k changes, that would be sufficient?
Got a VW, Audi, Skoda or Seat? I have full Diagnostic software VCDS to read and program your car. Need something enabling? Perhaps full diagnostic? Drop me a PM. Can diagnose in Camberley or Osterley Area.
  • Northampton
    • Not an Omega
« Reply #31 on: 21 November 2019, 15:28:07 »
Can I be cheeky and ask the same question about the 1.6 A16LER (2008 Corsa VXR)? Friend of my fiancée just bought one and I'm sure I'll be the first person to hear about it if/when it goes bang!
now: 2006 BMW 650i, 2007 Mini Cooper S, 2009 Range Rover Sport TDV8
ex: 2.5TD CD Estate, 3.2V6 Elite Estate
Fuse 19
« Reply #32 on: 21 November 2019, 16:04:29 »
Small block engine (family 1), been around a long time (distant origins in the old 8 valves from the Cav etc).
Generally no great issues, its the M32 manual box that was more problematic (although this had a big revision in around 2014ish which increased the size of one of the bearings, re-enforced the end case and improved lubrication......this end plate can be fitted to the older boxes to)
« Last Edit: 21 November 2019, 16:21:57 by Fuse 19 »
  • Northampton
    • Not an Omega
« Reply #33 on: 21 November 2019, 16:42:08 »
Perfect .. thanks! Here's hoping I never end up knee deep in bits of Corsa, then :y
Yodel-Odel-a-Eboy.com
  • Bring back the starting handle
    • The missus mad
« Reply #34 on: 21 November 2019, 18:05:36 »
Yes, the more recent Tourer variant. Although I see on the F/L they dropped the 'Tourer' brand.
Since the facelift 2 or 3 years back, its officially Zafira-C rather than Zafira Tourer.
I own a Zafira, I'm allowed to feel depressed.
    • The missus mad
« Reply #35 on: 21 November 2019, 18:06:49 »
I always use lots of 10W40 semi.  But as its so cheap from dealer, delivered, its not worth getting from anywhere else.
Pages: 1 2 [3]  All   Go Up
Page created in 0.148 seconds with 22 queries.
