Author Topic: Very simple Q - wiper blade arms  (Read 14334 times)
JohnM
  • Newark on Trent
    • 2.5M Estate
Re: Very simple Q - wiper blade arms
« Reply #15 on: 22 November 2019, 11:29:48 »
 ::) I did expect many replies - I was going to take the answers from the first two that agreed and hope the thread died out rather than morph but I've lost the plot.
I'm going with the, yes double, kink being the o/s = driver's (rhd) unless someone knows different. [when the time comes]
« Reply #16 on: 22 November 2019, 15:28:55 »
Why over complicate it?
The driver's blade is 24" and the passenger's is 21" from memory.
If you took the blades off the arms, you have earned the right to get confused ::)
« Reply #17 on: 22 November 2019, 18:43:23 »
whenever I've removed both wipers off a car I've put them down in order to prevent any confusion  :y
« Reply #18 on: 22 November 2019, 18:45:15 »
Oooooo....we're a proper fickin Edd China, aren't we?  ;D
« Reply #19 on: 22 November 2019, 18:47:50 »
Wood working will do that to a person :D
« Reply #20 on: 22 November 2019, 18:49:20 »
Isn't that just using a bit of common sense?  ::) ::)
« Reply #21 on: 22 November 2019, 18:49:35 »
;D ;D ;D ;D
« Reply #22 on: 22 November 2019, 18:49:54 »
Yeah...like wot Edd China does.
« Reply #23 on: 22 November 2019, 18:51:26 »
I'd guess that Ed China just has people undoing stuff for him so that he can simply undo bolts that have been under a car in the salt & water for 25 yrs  :y
« Reply #24 on: 22 November 2019, 18:58:38 »
Yeah, and sticking them onto big bits of cardboard with masking tape.
DrAndyB
  • The Wirral / Cheshire
    • 2.5 V6 CDX Manual (MFL)
« Reply #25 on: 22 November 2019, 20:26:08 »
Having reorganised the garage floor of bits from my dis pack removal task, and ahead of any refit in the future, can someone with a pre-facelift look at their car sometime for me to see which wiper arm is which please.
I *think* the one with the kink is the o/s arm and the straight arm n/s, but I'd like to confirm ahead.
Thanks.
 ;D ;D  I guess I had a beer  ;D ;D
Just checked my Mini-Facelift, and yes one with kink Passenger or O/S and straight arm drivers or N/S (this is from the hinge but you fold up).
The drivers one appears to have a double kink however at the spline or base end and passenger one a single kink at spline end if that helps.
Tother way around, drivers is offside.
« Reply #26 on: 22 November 2019, 20:27:51 »
Thanks.
Well, if you had a beer, and you got in the offside, you'd be in trouble. So best remember.  :P
JohnM
  • Newark on Trent
    • 2.5M Estate
« Reply #27 on: 22 November 2019, 22:33:31 »
Yes. Did this too. Ended up with more than more bits than I'd expected and moved them all lock, stock and barrel so I didn't trip over them. Then 'found' an arm.
I hadn't realised the arms were actually quite different lengths.  Touché.  Bend plus added kink arm earmarked for o/s.
« Reply #28 on: 22 November 2019, 22:43:52 »
I suppose the with the ease of digital photography these days, it could be said that all jobs could/should be photo'd before starting. Though when I've done it at work I often seem to miss the very bit I want to look at later  ;D
Enceladus
  • London
« Reply #29 on: 22 November 2019, 23:00:34 »
Drivers (offside) side is 24", 600mm, usually with an air spoiler.
Passenger (nearside) is 19", 480mm. standard blade.
Some makes provide a 450mm for the passenger side, that works fine as well.
The drivers (offside) wiper arm has a stub arm and a hinge. And is kinked.
The passenger (nearside) wiper arm has the hinge by the spindle.
