Author Topic: Finding part numbers  (Read 633 times)
JohnM
  • Newark on Trent
    • 2.5M Estate
« on: 22 November 2019, 12:07:18 »
Does anyone have a magic reference to part numbers or are they viewable somewhere online ?
I'm after the p/n for some extra parts as having had the plenum off I have been cleaning.
Rear air valve (mult-ram?) to plenum (sits inside the plenum) O ring (almost the size plenum O rings) - as I've been in to clean that up.
Breather bridge to throttle bodies, the 2 smaller O rings (not removed yet but will change if available) are these 90500983 ?
Throttle body to front plenum, pale O rings - 2 off (not disturbed yet as didn't want to pop out).
To confirm, also the plenum seal; is this 90467543 (x1) and the main plenum O rings 9118135 (x6) ?
The bridge breather setup was pretty much clean and clear (but even cleaner now!) but the rear valve hadn't been done and was quite gungy - not that I think it mattered but is better for it.
Enceladus
  • London
Re: Finding part numbers
« Reply #1 on: 22 November 2019, 14:58:17 »
Most of the seals can be reused. Excepting the camcover gaskets and the o-ring for the bolt holes. Some seals are no longer available so be careful with them. Just clean and reuse. Be particularly careful with the 'tophat' seal part nr. 90467543, that goes under the front end of the breather bridge. These are impossible to get. Although one member has a couple of spares, can't remember who, alas not me.
Crankcase Ventilation
Cylinder Head Covers and Gaskets
Induction Manifold (Contd.) [X25XE[L80],Y26SE[LY9],X30XE[L81],Y32SE[LA3] ENGINES]
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #2 on: 22 November 2019, 17:56:54 »
I suspect most V6 owners have secret stash they don't admit to  :D
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #3 on: 22 November 2019, 18:00:04 »
What's the first rule of fight club Vauxhall spare part hoarding club ?  :-X
« Reply #4 on: 22 November 2019, 18:22:53 »
oops! ....fair point  :-X
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #5 on: 22 November 2019, 18:30:59 »
I think Enceladus may have been referring to me re-the "top hat" seals as my son sent me 4 over from the U.S.A.[although I have promised one to DBG]the "o" rings I'd have thought would be available from a decent motor factor[take one in as a pattern]or buy a box full of assorted size "o" rings? Again I have a set of GM "o" rings in my "stash"-whether I'll ever use any of these is open to question-along with the "top hat" seals,all I've got to do now is remember where I've stashed my stash :D
biggriffin
  • huntingdon, Hoof'land
    • Vectra in a posh frock.
« Reply #6 on: 22 November 2019, 18:38:35 »
 Mine are slowly, coming to light, and being sold :D
Hoof'land storeman.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #7 on: 22 November 2019, 19:49:57 »
SAAB hoarder now then  :D
« Reply #8 on: 22 November 2019, 19:52:52 »
Cheers Baza, hopefully when we're up for Xmas we'll come via the land of ladyparts, and pick it up. Thanks for remembering me  :y
JohnM
  • Newark on Trent
    • 2.5M Estate
« Reply #9 on: 22 November 2019, 23:02:40 »
Thanks, esp. the vauxhall.7zap.com references.
At least I'll know what to (try and) ask for.  The plenum O rings are a bit flattened, I'd change those if possible.  The rear flap valve (because it is hard to get to if leaks), the others (to the front) could, at least, be changed as and when without too much trouble.
Are pattern parts any good for seals/O rings (normally I'd stay away from them) - unless these too are made form unobtainium.
Jan Suhr
  • Nyköping, Sweden
    • 2 Omega Caravans 3.2 V6
« Reply #10 on: 23 November 2019, 08:15:45 »
Living in Sweden I have found that some parts that are not available as Vauxhall/Opel parts can have a SAAB part number that are available. They had the V6 in some of the SAAB's.
You need a good parts guy that is willing to look a bit further to find the stuff you need.
Jan Suhr
Stockholm, Sweden
www.protouring.se
Page created in 0.132 seconds with 22 queries.
