Pages: [1] 2 3  All   Go Down
Author Topic: How does Astra power steering work?  (Read 1346 times)
terry paget
  • Midsomer Norton Somerset
    • 1 Omega 3 Astras 2 Vectra
« on: 22 November 2019, 17:48:27 »
Astra H 1.6 manual 2006
I know it's electrical; I thought an electric pump drives an hydraulic system similar to the Omega system, but is more efficient as it only operates when needed. Haynes infers it is all electric, if so I don't understand how it works. Please enlighten.
  • Online Online
Re: How does Astra power steering work?
« Reply #1 on: 22 November 2019, 17:50:01 »
Motor drives the steering column :y
terry paget
« Reply #2 on: 22 November 2019, 19:59:13 »
Thanks Doc. Still not clear how it works. In Haynes 2004-2008 it says system is electro-hydraulic, ECU is advised by ABS (speed) and a steering angle sensor. Hydraulic pump, reservoir and motor are mounted above the rack and pinion steering.
Haynes 2009-2013, however, states that electric power assisted steering is fitted. It may be the same system, but the description is different, more vague, and does not use the word 'hydraulic'.
I only ask because today my son Ben, with his son Tom (5 last Friday), got into their Astra to leave my house, but came back complainng that his steering 'did not work'. I got in the car and tried it, suspected the power steering, and with engine running tried to turn the steering. Initially the steering was very heavy, but gradually it got lighter and retured to normal. I handed the car back to my son, who drove home in it.
I hope Tom was impressed.
Are the 2006 and 2009 systems identical?
    • R320 TDM850 SmartRoadster
« Reply #3 on: 22 November 2019, 20:00:55 »
Astra G was electro/hyraulic Astra H is electric only
  • Online Online
« Reply #4 on: 22 November 2019, 20:06:17 »
The electro hydraulic system is pretty much identical to the traditional one... Only difference is that the pump is electric rather than belt driven... Pump is moved to the rack for convenience/packaging purposes ;)
« Reply #5 on: 22 November 2019, 20:10:16 »
Pump or motor?
The electric assisted steering on my Smarts don't have a pump (just been to look at my ML and that appears to be electric only too which is probably how it steers itself when self parking)
  • Up North
    • Astra 2.0 diesel
« Reply #6 on: 22 November 2019, 20:25:49 »
Motor on the rack
If you are offended by anything I post, sorry. Just thought I'd get that in now.
  • Up North
    • Astra 2.0 diesel
« Reply #7 on: 22 November 2019, 20:29:00 »
That's the J, by the way.
dave the builder
  • Online Online
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #8 on: 22 November 2019, 20:29:48 »
astra H is electric pump to pump hydraulic oil on most models same as astra g
astra F had a belt driven pump like the omega
Astra H like this clicky
if the rack or pipes leaks ,the reservoir may need topping up short term
remember you have a spares car Terry
  • Up North
    • Astra 2.0 diesel
« Reply #9 on: 22 November 2019, 20:31:58 »
I knew the astra expert would be along  :y
  • Online Online
« Reply #10 on: 22 November 2019, 20:32:47 »
Pump or motor?
Motor driven pump assembly :P
dave the builder
  • Online Online
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #11 on: 22 November 2019, 20:34:03 »
if no leaks, there is a relay somewhere and a sensor on the column  :y
I knew the RUSTY VAUXHALL  expert spanner monkey would be along  :y
FTFY  ;)
  • Up North
    • Astra 2.0 diesel
« Reply #12 on: 22 November 2019, 20:36:05 »
FTFY  ;)
Aye, well, you'd be f****d with the wife's K, it's an electronic nightmare.  ;D
  • Up North
    • Astra 2.0 diesel
« Reply #13 on: 22 November 2019, 20:36:29 »
And it's not rusty.....yet.
dave the builder
  • Online Online
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #14 on: 22 November 2019, 20:43:04 »
And the screenwash is rusting the interior floor and electric gubbins  away nicely
FTFY  :y
Pages: [1] 2 3  All   Go Up
Page created in 0.134 seconds with 22 queries.
