Author Topic: Auxillary belt tensioner pulley V6  (Read 4159 times)
artsoul_no1
  • sidcup, kent
    • Omega CD 2.6 v6 2002
« on: 24 November 2019, 11:08:15 »
Hi all
Trying to undo and replace auxillary bely tensioner pulley but nut is a bit stiff. Before I go to town on it can anyone confirm whether it is a standard or reverse thread
Thank you
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: Auxillary belt tensioner pulley V6
« Reply #1 on: 24 November 2019, 12:24:36 »
Standard.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #2 on: 24 November 2019, 12:53:23 »
STD 15mm, remove, take seal out of pulley, clean bearing race, re-grease, refit. :y
Hoof'land storeman.
« Reply #3 on: 24 November 2019, 13:07:58 »
Use a half inch breaker rather than a ring spanner ;)
Refitting is bft against the tensioner spring.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #4 on: 24 November 2019, 14:24:17 »
if it's really bad then a brand new pulley costs under a tenner. You don't need to replace the entire assembly.
Idler failure is a big cause of multi-pulley belt faults, not just on Omegas, so the  few minutes it takes to loosen the belt, grease the idler bearing and refit the belt is worth adding to your service schedule.
Every other annual service or whenever you remove the belt for other work would be enough :y
« Reply #5 on: 24 November 2019, 14:50:13 »
Standard thread, but the nut is self tightening, so if its been on a while, it needs a long lever.
Regreasing is OK as long as there is no wear, and its just dry.  If any play, notchiness, unevenness, replace the pulley.  If you go to a dealer, some argue its only available as part of the tensioner, but that's incorrect.
We have seen tensioner pulleys cause the aux belt to fail, and take out the cambelt, which in turn takes out the valves.
artsoul_no1
  • sidcup, kent
« Reply #6 on: 25 November 2019, 14:17:08 »
Thanks Nick
It hasnt been off since you greased it a few years back. Got a new pulley and belt ready to go on
artsoul_no1
  • sidcup, kent
« Reply #7 on: 25 November 2019, 14:17:37 »
Thanks for all the replies much appreciated
artsoul_no1
  • sidcup, kent
« Reply #8 on: 27 November 2019, 10:28:21 »
All done. Thanks for everyones help much appreciated
neil74
  • newport
    • 2.6 elite estate.
« Reply #9 on: 27 November 2019, 13:36:40 »
My tensioner completely seized up and started to shred the belt.. but I was lucky because I had just pulled up outside the house and noticed the god awful noise it was making and switched off quickly.
artsoul_no1
  • sidcup, kent
« Reply #10 on: 27 November 2019, 13:43:39 »
Mine sounded like a fishing reel changed just in time I think
Enceladus
  • London
« Reply #11 on: 27 November 2019, 13:57:50 »
I imagine it's a good idea to inspect & re-grease/replace the aux tensioner pulley/roller on all models of Omega, not just the V6.
terry paget
    • 3 Astras 2 Vectra
« Reply #12 on: 27 November 2019, 21:46:35 »
2.5 manual petrol estate
I suffered failure of the auxiliary belt pulley bearing driving from my son Jonny's wedding in Bristol to the reception in Dawlish Warren, south Devon, about ten years ago. It was a cold November night, I was about 5 miles short of my destination. Lights went dim, power steering failed, warning lights came on. Car still ran, but soon overheated. I managed to drive 2 miles further. I walked the last 3 miles to the reception.
AA recovered the car to my home 2 days later. I replaced pulley, bearing and belt.
I agree wite the above advice. Now I grease the bearing every 2 years.
Migv6 le Frog Fan
  • Online Online
  • Webs End.
  • Nicole's Papa
    • 3.2 Elite. Boxster. C1.
« Reply #13 on: 27 November 2019, 22:03:19 »
Had the same thing on my previous Omega several years ago. First time I ever used breakdown recovery to get home. Luckily no damage done apart from pulley breaking up and shredding the belt.
Reading this thread has made me decide to replace the pulley and belt on my current car at the next service, which is due in the next couple of months.
Women are like an AR35. lovely things, but nobody really understands how they work.
  • Chatham, Kent
« Reply #14 on: 28 November 2019, 10:15:56 »
it's worth doing whatever car(or machine) they're fitted to. Which is most these days, as ribbed belts are more efficient than vee, and make a more compact installation.
