Author Topic: Ford Fusion/Fiesta automatic gearbox fluid level  (Read 7027 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« on: 26 November 2019, 13:23:07 »
Goooooood afternoon my fellow omega freaks, I mean friends 🤔🤣🤣🤣
Mummy Bears 🐻 automatic 2006 Ford Fusion (which I believe has the same automatic transmission they put in the fiesta) has had a bit of attention lately. I’ve replaced the auto box selector switch (which Ford call a “range sensor”), I’ve serviced it, put a new condenser in, fitted a new wing mirror. Anyway it has a drain plug for the auto box so I am going to change the fluid. I’ve done this before but I’ve forgotten the level check procedure. It has a dip stick which I thought was an American thing. Am I right that I do the drain. Refill through the dipstick tube. Give it a run. And then check level with the car warm and still running....
Cheers boys 😍😍😍
RIP Paul Lovejoy
Re: Ford Fusion/Fiesta automatic gearbox fluid level
« Reply #1 on: 26 November 2019, 13:36:44 »
Durashift EST or the equally awful Durashift CVT?
Webby the Bear
  • Northampton
« Reply #2 on: 26 November 2019, 13:47:34 »
The Durashift EST is the semi automatic one I thought?
This is just a straight up auto box.
RIP Paul Lovejoy
« Reply #3 on: 26 November 2019, 15:09:12 »
SO its possibly the Aisin AW80 then?
Webby the Bear
  • Northampton
« Reply #4 on: 26 November 2019, 15:30:17 »
Not sure. I’ll ring ford and get the code...
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #5 on: 26 November 2019, 15:49:10 »
Bang on mate. 4 speed automatic AW80 👍
If you’ve got a level check procedure that’d be amazing 😊😊😊
RIP Paul Lovejoy
« Reply #6 on: 26 November 2019, 17:11:54 »
Its the same as used in the Astra etc so same procedure (there was an online workshop manual).
Its usually fill to the max mark, run through all the gears and get it warm, check and top up
« Reply #7 on: 26 November 2019, 17:24:01 »
Prior to fluid level check: Let engine run in idle for one minute with selector lever in "P" position. Shift selector lever once through all positions from "P" to "1" and then back again.
Caution
Prior to and during fluid level check, selector lever must be in "P" position with engine running.
Note:   Shake transmission fluid can (1) prior to use (as shown in pictogram (2)), to ensure mixture of the additives. If this is not observed, the fluid foams up during driving operation, which can lead to faults in the transmission.
Measure transmission fluid temperature with TECH 2 – see Checking Procedure "AF 13-II/AF 17/AF 20/AF 22 Automatic 4-Speed Transmission Astra-G ". Charge transmission fluid to relevant upper mark.
For cold transmission (below + 35 °C ambient temperature, within one minute with engine idling) correct fluid level must lie between markings on the side of fluid dipstick showing "MIN + 20 °C".
For warm transmission (approx. 80 °C – after travelling distance of approx. 20 km) correct fluid level must lie between markings of fluid dipstick showing "MAX + 80 °C".
Or
Fill to max if no temperature markings on the dipstick
That's the GM one
« Last Edit: 26 November 2019, 17:28:31 by Fuse 19 »
Webby the Bear
  • Northampton
« Reply #8 on: 26 November 2019, 18:08:36 »
Thanks fuse.
I’ve looked on the dipstick and it says 50 degrees. So I drain. Fill with same amount removed. Drive n get it warm. Put in park. Get level to max.
RIP Paul Lovejoy
