Pages: 1 [2] 3  All   Go Down
Author Topic: Radiator part number needed  (Read 5120 times)
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
Re: Radiator part number needed
« Reply #15 on: 02 December 2019, 19:19:10 »
Which radiator did you eventually go for. The £44 one recommended by Doc Gollum or the £80 Vaux?
Please let us know if there were any issues fitting it?
Thanks,
Went with the £44 one recommended by Doc Gollum. Will be fitting it towards the end of this week if all goes well. Will let you know how the fitting goes.
Andy A
  • Bristol UK
« Reply #16 on: 11 December 2019, 13:46:39 »
What is the torque settings for the radiator fan switch's?
Is it a 29mm or 30mm spanner size? I don't have one so will have to order one.
Will I have to renew the dowty washers?
Thanks
« Reply #17 on: 11 December 2019, 17:33:56 »
30mm iirc, and switches should come with new washers ;)
« Reply #18 on: 11 December 2019, 18:47:05 »
I wouldn't buy a 30mm spanner to just do one job, unless it was very cheap. I'd buy a gland pliers for a one off job or maybe a cheapo adjustable spanner.
« Reply #19 on: 11 December 2019, 18:54:03 »
There are a couple of jobs on the Omega which warrant a larger offset ring spanner ;)
Not sure if the switches fit through one though... Honestly can't remember  :-[
Fit them with the radiator out and space isn't a concern, so a large adjustable would suffice  :y
Enceladus
  • London
« Reply #20 on: 12 December 2019, 03:31:32 »
Seems to me that the spanner flats are 29mm.
The tightening  torque will depend on the type of washer that being used, supplied with the switch. A Dowty will require less torque than a crushed aluminium type. And some washers might be fibre.
  • Chatham, Kent
  • Rover Metro 1.8VVC
    • 3.0l Elite estate
« Reply #21 on: 12 December 2019, 10:08:21 »
that. There's not much space to get tools to the switches when the radiator is fitted.
Bear in mine you're screwing them into a plastic housing, and the sealing is done by a crushable washer so they need little more than nipping up. Water pump pliers will do that.....
Andy A
  • Bristol UK
« Reply #22 on: 16 December 2019, 21:00:58 »
Ive got another problem and need some help please ASAP.
The oil cooler pipe in the new rad is leaking water out of the the centre fitting. Can only guess a bad solder joint on the pipe fitting inside the rad.
What size bolt would I need to blank the oil cooler pipe rad inlet and outlet off to stop the leak?
I'm so glad I have a manual and not an auto box.
I need the car back on the road ASAP.
Thanks for any advice and help.
Enceladus
  • London
« Reply #23 on: 17 December 2019, 02:09:46 »
Ouch!
So coolant is leaking into the auto box heat exchanger and coming out of one of the transmission connectors?
That absolutely should not be happening.
You mentioned there were no blanking bungs.  That struck me as a bit odd, if for no other reason than to prevent grime and debris out of the heat exchanger and contaminating the ATF. Assuming it was to be fitted to an auto. Are you certain the rad was brand new? Might it have been somebody else's faulty return?
I think the thread in the ports might be M14, but I won't swear to it.
You probably need a seal for each blanked port as well. Perhaps an oil pan drain plug and M14 Dowty washer might fit. The sump plugs might be short enough and will have a sealing land below the bolt hex.  They should be easily available from any motor factor.
However I'd be more inclined to demand a replacement working rad, by courier, from carspares-direct. I just couldn't trust your radiator, even though you're not using the heat exchanger.
« Last Edit: 17 December 2019, 02:19:17 by Enceladus »
Enceladus
  • London
« Reply #24 on: 02 May 2020, 16:40:38 »
@Andy A
Any update on how this all worked out?
Did you have to get a replacement radiator from carspares-direct or somewhere else?
Andy A
  • Bristol UK
« Reply #25 on: 02 May 2020, 19:04:31 »
@Andy A
What happened is that I got fobbed off several times so I went out and bought 2 sump plugs, the ones with the rubber o-rings on. This cured the leak coming from the internal oil cooler pipes.
I'm just glad I didn't have an Automatic as the gearbox would have been full of coolant. I advise to stay well clear of that company.
« Reply #26 on: 02 May 2020, 19:51:08 »
I recommended it on price iirc, not my usual choice of supplier, but £44 looked cheap enough to take a chance, sorry that it didn't work out that way  :-\
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #27 on: 02 May 2020, 20:02:51 »
there was a spate of similar coolant /trans cooler fails (coolant going into the auto gearboxes) on genuine Vauxhall rads a few years ago on some models  :(
Andy A
  • Bristol UK
« Reply #28 on: 03 May 2020, 08:41:41 »
Don't worry about that Al. It was worth ago at that price.
The firm itself though is another matter.  :o
Andy A
  • Bristol UK
« Reply #29 on: 03 May 2020, 08:46:00 »
Surprised that the genuine Vauxhall rads had the same problem.
Pages: 1 [2] 3  All   Go Up
Page created in 0.032 seconds with 21 queries.
