Pages: 1 [2] 3  All   Go Down
Author Topic: My Builder's Van MOT  (Read 731 times)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: My Builder's Van MOT
« Reply #15 on: 02 December 2019, 16:28:04 »
Well, the Omega passed but it did have a couple of advisories on front disc inner face corrosion and play in a balljoint. A couple of little jobs for after Christmas I think.
Excellent  :)
congratulations on the pass  :y
front brakes are a piece of p155 on Omegas anyway
ball joint  :-\ I assume bottom one on the wishbone ?
Migv6 le Frog Fan
  • Online Online
  • Webs End.
  • Nicole's Papa
    • 3.2 Elite & Welsh Hatch
« Reply #16 on: 02 December 2019, 16:30:32 »
Yep bottom balljoint, which is bolted on as I replaced them before, so also an easy job.
Plastic Welsh hatchbacks are awesome.
I would like to know what will happen this year, but I don't have 20 20 vision.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #17 on: 02 December 2019, 16:34:37 »
Yep bottom balljoint, which is bolted on as I replaced them before, so also an easy job in the snow at minus 15 degrees
FTFY  ;)
Migv6 le Frog Fan
  • Online Online
  • Webs End.
  • Nicole's Papa
« Reply #18 on: 02 December 2019, 16:44:03 »
Im too old and facked for that sort of caper. Parts will be sourced and then fitted on a day when the weather isn't too Baltic, whenever that may be. If it has to wait until April then so be it.
« Reply #19 on: 02 December 2019, 17:42:29 »
Discs are a common 'not driven enough' issue ;)
Easily rectified, as you say :y
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #20 on: 02 December 2019, 17:47:04 »
yep
dump CL-Eeyore and drive the Omega all the time  ;D
Migv6 le Frog Fan
  • Online Online
  • Webs End.
  • Nicole's Papa
« Reply #21 on: 02 December 2019, 18:39:29 »
If I could afford to drive the Omega all the time I would get rid of it and buy a Boxster.
It has done less than 4k miles in the last year, so that will be a contributory factor in the discs problem. Might try and get some genuine VX discs before Trade club shuts down.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #22 on: 02 December 2019, 19:10:38 »
If the Omega is spending long periods of time parked up ,no point in swapping the discs surely  :-\
they will just rust again
strip and clean the caliper guides, lube them etc to make sure they are free if worn or rusted inside
sticking caliper or piston  :-\
Yodel-Odel-a-Eboy.com
  • Bring back the starting handle
    • The missus mad
« Reply #23 on: 02 December 2019, 19:11:09 »
Many Vauxhalls suffer this, where the inner face gets badly corroded , starting at the outer circumference and slowly working inwards.  Never seen this on other cars I've owned.  My MV6 and TB2 aside - where I tended to wear out the discs before this happened - this has happened on all my Omegas, and the Zafira. and the Nova...
I own a Zafira, I'm allowed to feel depressed.
Migv6 le Frog Fan
  • Online Online
  • Webs End.
  • Nicole's Papa
« Reply #24 on: 02 December 2019, 19:22:10 »
Yup, so best to accept it as one of those foibles all cars have and change them once in a while. Probably about every three years/ 12k miles in my case.
  • Northampton
    • Not an Omega
« Reply #25 on: 03 December 2019, 08:58:29 »
I've seen that on almost every car I've owned - the MR2 was notorious for it (almost everyone would report the same problem, regardless of miles driven), the MINI discs were the same when I took them off.. haven't had it, however, on the BMW (genuine BMW discs) and we'll see how the MINI holds up now it too is running genuine BMW discs. Even the OE Toyota discs would do it, though. People would try painting the outer edge and top hat to no avail.
now: 2006 BMW 650i, 2007 Mini Cooper S, 2009 Range Rover Sport TDV8
ex: 2.5TD CD Estate, 3.2V6 Elite Estate
    • R320 TDM850 SmartRoadster
« Reply #26 on: 03 December 2019, 10:19:55 »
You can watch my Merc's brake discs rust ......  ;D
  • Northampton
    • Not an Omega
« Reply #27 on: 03 December 2019, 10:22:59 »
You'll stay warmer coming inside and watching paint dry, though..  :D ;D
Sir Tigger QC
    • 2 Fords
« Reply #28 on: 03 December 2019, 10:57:58 »
That involves doing some decorating though...  :-\  ;D
JC is not The Messiah, he's a very naughty boy!!
Migv6 le Frog Fan
  • Online Online
  • Webs End.
  • Nicole's Papa
« Reply #29 on: 03 December 2019, 10:59:38 »
Was going to have a look at the latest TC price for a set of discs / pads, but its been so long since I logged into the site, Ive forgotten the login details......again.
Pages: 1 [2] 3  All   Go Up
Page created in 0.139 seconds with 22 queries.
