Author Topic: Misfire cylinder 2  (Read 5867 times)
Patriciajosephine
  • Cwmbran
    • Vauxhall omega 2.6 6v lp
Misfire cylinder 2
« on: 01 February 2020, 18:59:28 »
Hi
I have omega 2.6 v6 and its misfiring... code reader at garage said cylinder 2. My husband would like to know Where this is positioned please.
Life can be an uphill struggle but with support it gets easier 😊
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
Re: Misfire cylinder 2
« Reply #1 on: 01 February 2020, 19:26:50 »
As I understand it cylinder 2 is the front one on the passenger side[rhd car] I believe it goes[front to rear of engine] 1 3 5 on drivers side and 2 4 6 on passenger side.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #2 on: 01 February 2020, 20:01:22 »
Cam cover gaskets, oil in plug wells, O and blocked breathers.
Hoof'land storeman.
Patriciajosephine
  • Cwmbran
« Reply #3 on: 01 February 2020, 22:12:51 »
« Reply #4 on: 01 February 2020, 22:22:24 »
Does it have lpg fitted as that will complicate things slightly...
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
« Reply #5 on: 02 February 2020, 01:04:50 »
Equally, the misfire could also be water in the plug wells as a result of rain water leaking off the scuttle. On my V6's, any misfire, especially diagnosed on cylinders 2 / 4 / 6,  has been caused by water ingress, rather than oil. Plenty of discussion and well documented on here.
biggriffin
« Reply #6 on: 02 February 2020, 08:22:55 »
 Ooo forgot about that, water coming from the scuttle straight into the coil pack,,  I stopped mine by putting a Heath-robinson cover over the coil pack which was bolted to the plenum, never had a problem after that...
Hoof'land storeman.
Patriciajosephine
  • Cwmbran
« Reply #7 on: 02 February 2020, 12:10:22 »
Hi where can i obtain keirh robinson cover please and what is it
Patriciajosephine
  • Cwmbran
« Reply #8 on: 02 February 2020, 12:13:35 »
Also the lpg system stag and injectors and ecu replaced 2 years ago
hotel21
  • The Kingdom of Fife
« Reply #9 on: 02 February 2020, 12:20:03 »
If something is described as 'Heath Robinson' then it means home made, to no specific design, other than to do the job intended.  It could be quite well made, of well thought out design with purpose and longevity to the for or it could be anything available to hand, held together by string and hope, as long as it does its job.
In this case, search the help and maintenance guide for scuttle drain and look at the results.
« Reply #10 on: 02 February 2020, 12:44:11 »
When were the plugs last changed?
« Reply #11 on: 02 February 2020, 12:55:08 »
Is the misfire on both petrol and LPG or just LPG ?? (try running with LPG off to check). LPG is "harder" to ignite than petrol so is much more sensitive to problems.
Patriciajosephine
  • Cwmbran
« Reply #12 on: 02 February 2020, 14:12:37 »
Petrol ... but can misfire later on lpg... thanks for all  suggestions fab  :y
biggriffin
« Reply #13 on: 02 February 2020, 14:45:01 »
There was a picture somewhere, but I can't find it,, basically I cut a sheet out of a gallon oil can, this put a cover over the coil pack, and was attached by the plenum cover bolt.
Hoof'land storeman.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #14 on: 03 February 2020, 10:23:20 »
'Heath Robinson' just means a quick and dirty one-off solution to a problem, using stuff you have lying about, with no effort put into aesthetics or fit and finish. So named after a series of cartoons depicting outlandishly complicated devices to solve simple problems.
All this job requires is a cover that directs scuttle leaks away from the coil pack.
Fixing any leaks removes ALL need for such a thing, and removing the scuttle foam(quick, easy and free) reduces the problem to almost nothing.
