Author Topic: Alternative Tech 2 ?  (Read 8131 times)
iggy21uk
  • Berkhamsted - Herts
  • Omega Spotter -  tats gone tanning
« on: 15 July 2006, 20:19:21 »
Copied from site - hope thats ok ??
VAUX-COM comes complete with all the hardware and software to connect your PC or laptop computer to almost any Vauxhall car or light van There are two versions of the VAUX-COM tool available. The standard and Pro-Kit.
The VAUX-COM PC / Laptop based diagnostic tool for Vauxhall
Works with almost all current Vauxhall models made from 1997 to 2005
Covers engine, airbag, ABS, alarm, instruments and many more
Reads fault codes from all modules and displays full English text for them
Clears fault codes from all modules
Shows live sensor data as seen by the cars ECU
Allows you to operate relays, solenoids and actuators
Program new keys and remote fobs (pin required)
AND  works on USB --    Whats the price I ask ???????
More info:  http://www.onboarddiagnostics.co.uk/diagnostic_tools/vaux-com/vaux-com_hardware_details.html
« Last Edit: 15 July 2006, 20:24:10 by iggy21uk »
[size=10]Opelscanner Can owner / Cam lock kit owner [/size] [/i][/b]
Re: Alternative Tech 2 ?
« Reply #1 on: 15 July 2006, 20:33:27 »
looks good, not sure how good the software is. Expensive i would imagine  :(
Markjay
  • London
« Reply #2 on: 15 July 2006, 23:51:58 »
The software looks surprisingly similar to the Opel Tech for the 'cheapo' Tech2. In fact, it looks like the final version of the Opel Tech software. See:
http://www.onboarddiagnostics.co.uk/diagnostic_tools/vaux-com/vaux-com_demo_movie.html
Now I wonder if it will work with the Cheapo Tech2....
Alas, no more Omegas....
iggy21uk
« Reply #3 on: 17 July 2006, 12:51:28 »
Standard Kit - £490 + Vat. Pro Kit  - £540 + Vat
So not cheap. But cheaper than the proper Tech 2
« Reply #4 on: 17 July 2006, 12:55:44 »
Much cheaper than a real Tech2, but much less capable as well...
If you're after a cheap fault code reader for pre ODBII/EOBD Omegas, the cheapo tech2 lead is probably still best option.  Unless you live near me of course ;)
v6man54deg              Geffd
  • Wirral Merseyside
  • V6 man
« Reply #5 on: 17 July 2006, 20:16:28 »
It shows live data - and has actuator tests so worth the money I would say
V6 problems solved : Worked at the V6 Engine plant for 13 years on durability testing and warranty issues, this job included many trips to Russelsheim, Trollhattan, Michigan, Atlanta,keiserslaughtern.
Page created in 0.023 seconds with 20 queries.
