Pages: 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 ... 1317   Go Down
Author Topic: So what have you done to your car today?  (Read 1193965 times)
0 Members and 3 Guests are viewing this topic.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #105 on: 04 May 2011, 23:17:48 »
Collected another Range Rover, gave it a needed wash inside & out.. get it ready for its MOT  :y
19.7 mpg sat at 80mph and you complain about Omega's ;D ;D ;D ;D ;D
Eh! What year/engine/spec is that?
V8 4.6 HSE :y
geoffr70
  • Sunderland
  • Boobies
    • F/L 3.0 Elite, 3.0 MV6
« Reply #106 on: 04 May 2011, 23:24:10 »
V8 4.6 HSE :y
Ouch! You're right i do whinge about the omega, it was on 20 mpg, the highest in a long while (probably the warmer weather), then I only went and took it for a blast! Think I'll stick with it though! Dare I ask the urban mpg?
« Last Edit: 04 May 2011, 23:24:31 by geoffr70 »
TC and BnQ Trade holder.
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #107 on: 04 May 2011, 23:30:13 »
V8 4.6 HSE :y
No  ;D ;D ;D ;D
About 14mpg
I had one that I put £60 worth of petrol in it and I did 50 miles  ;D ;D ;D ;D ;D the O2 sensors where sho,t so I drove and collected the new ones and fitted them at the side of the road, so on the drive home I thought I had won the lottery when it was doing 19 ;D ;D ;D ;D ;D
« Last Edit: 04 May 2011, 23:31:07 by Loo-knee »
DaveA
  • Leicestershire
    • Insignia CDTI SE 160
« Reply #108 on: 05 May 2011, 09:30:37 »
Gave car good clean inside and out, checked all the fluid levels, including gear box, pumped tyres up to full load pressure, everything seems OK, off on hols tomorrow(6th) :y
M.O.T booked for the 16th May, day after I get back. :(
« Last Edit: 05 May 2011, 09:32:01 by DaveA »
Regards
    Dave
  • Chatham, Kent
  • Rover Metro 1.8VVC
    • 3.0l Elite estate
« Reply #109 on: 05 May 2011, 12:49:44 »
Had the A/C regassed today. Now the entire climate control works properly, and doesn't just run with the fan on full trying to do 'something.'
Wishbones are next to fix the awful crashing from the front N/S.
geoffr70
  • Sunderland
  • Boobies
« Reply #110 on: 05 May 2011, 22:11:52 »
Picked up my KYB springs and fitted them to the Elite, easier than I thought. I don't think I would've been able to do it without spring compressors though as I didn't drop the exhaust. New springs are about 3/4 inch maximum taller than old ones - I don't know how old the old ones are but that's alot of sinkage! I thought about grinding off the bottom of the old spring instead of getting new ones, but at £108 you can't complain. I am fitting a towbar and will be towing kevin the caravan, and it's got new shocks and donuts so why not! I forgot to clip the ABS sensor wires back on! Doh, that's a job for the morning before I go to work.
« Last Edit: 05 May 2011, 22:12:36 by geoffr70 »
« Reply #111 on: 06 May 2011, 07:03:55 »
Removed Bose shelf in an attempt to fit a donut tank in the spare wheel well, still didn't fit. But got a blind to go in, and the Bose amps going in the first aid cupboard anyway. So busy tomorrow.  :y
Yodel-Odel-a-Eboy.com
  • Bring back the starting handle
    • The missus mad
« Reply #112 on: 06 May 2011, 08:57:32 »
The loom fitsnicely, but you have to extend sub speaker wires. Ran my sub wires above shelf, so grommets as well reqd
I own a Zafira, I'm allowed to feel depressed.
Fuse 19
« Reply #113 on: 06 May 2011, 11:34:53 »
What did you do for a bracket?
« Reply #114 on: 06 May 2011, 11:59:38 »
One for pre face cd changer...?  Which I don't have, might have to make sumat  :-/
« Last Edit: 06 May 2011, 12:00:44 by chrisgixer »
    • The missus mad
« Reply #115 on: 06 May 2011, 12:27:24 »
As gixer says, prefacelift cd changer cage
    • The missus mad
« Reply #116 on: 06 May 2011, 14:19:39 »
Today I dropped TBE in to a garage for some work  :-[
« Reply #117 on: 06 May 2011, 14:27:52 »
No harm in that... I'll have to do the same as I must get mine inspected ::)
« Reply #118 on: 06 May 2011, 14:30:23 »
 :o You must have been busy tidying your garage. Or.. :-X
Martian
« Reply #119 on: 06 May 2011, 15:19:56 »
You lucky sod.
Petersfield to Hindhead (a distance of 15 miles) on the A3 coming back from Pompey one nice sunny evening and I found myself sharing some rather spirited driving with an Evo owner.
350 cubic inches (that's 5.7 litre) and fed by a 600cfm 4 barrel Holley saw me get 6mpg over that 15 mile run with the Evo, but he pulled in to the petrol station at Hindhead lights last so it was worth it  :) :) :)
« Last Edit: 06 May 2011, 15:24:47 by Martian »
Pages: 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 ... 1317   Go Up
Page created in 0.112 seconds with 22 queries.
