Pages: 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 ... 1751   Go Down
Author Topic: So what have you done to your car today?  (Read 3018144 times)
0 Members and 13 Guests are viewing this topic.
« Reply #120 on: 06 May 2011, 18:19:36 »
Today I dropped TBE in to a garage for some work  :-[
 :o You must have been busy tidying your garage. Or.. :-X
I came out £100 lighter  :-[
Omega AOS2002
  • Havant, Hampshire
« Reply #121 on: 06 May 2011, 21:23:34 »
Only driven it today.
Hope it doesnt need fixing for a while
« Reply #122 on: 06 May 2011, 21:42:48 »
Full strip down of front brakes, fluid change suspension check and started to clean the alloys.
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
« Reply #123 on: 07 May 2011, 08:21:53 »
My Elite is having a free wash at the moment (it's pi^%ing down here) ;D ;D ;D ;D
tigers_gonads
  • Kinston Upon Hull
  • Driving a Honda CR-V which doesn't smell of pee
    • Honda CR-V
« Reply #124 on: 07 May 2011, 16:18:36 »
Spent 52 quid on it this morning  ;)
On bloody petrol  :'( :'(
Hopefully that will sort me out till I can gas it  :y
70.9 ltr round here  :y
Phil H.
  • stamford lincs
« Reply #125 on: 07 May 2011, 16:26:25 »
Only driven the brats-sorry i mean my lovely kids ;) - to horse riding lessons. daren't drive it too far nor hard coz of ongoing probs  :(
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #126 on: 07 May 2011, 18:28:05 »
- plumbed in the vapouriser coolant pipe from the back of the coolant bridge around the front in preparation of lpg install
- replaced the HBV
- replaced thermostat (and coolant bridge pipe  )
- replaced most of the coolant piping at the back
- fitted the inlet manifold that KW kindly tapped for me
- replaced the leaking camshaft seal.
knackered now ;D ;D
o-meg-a
  • south wales
  • avatar disabled meantime as its mahoosive!
« Reply #127 on: 07 May 2011, 18:31:44 »
-Fitted Elite alloys (16")
-Fitted Elite Grey leather
-Oil and Filter change
-Fuel filter change (full of diesel magic)
-Wash and polish
-New air filter
-New pollen filter
Things to do - Fit new exhaust (back box and middle box)
                  - Find and fit Front cenre arm rest (entire unit, as mine is base spec)
                  - Fit wishbones
                  - erm.....lol
« Last Edit: 07 May 2011, 18:35:00 by o-meg-a »
Big_Al
« Reply #128 on: 07 May 2011, 18:46:41 »
Breather clean . Were Ok actually, but still gave them another clean out.  as you never know if previous owner had done it properly  ::) ::)
Oil & filter again. Changed oil & filter when i got the car at end of Feb. Done just over 1000 miles now. Next change will be in another 2000 ;) ;) ;) Then every 3000 or so.
Brakes next on list.
 Quite like the painted & labelled caliper thing :D :D :D
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #129 on: 07 May 2011, 19:11:42 »
It's getting another free wash as it's doing it again, hope it gets the bird poo off the drivers window this time  ;D ;D
Omega_Dan
« Reply #130 on: 07 May 2011, 19:24:25 »
Finally done something! Changed side indicator repeaters to clear ones and flatened, Painted and Lacquered my front grill Black :y
« Reply #131 on: 07 May 2011, 22:46:43 »
whole day sanded my car.. not the miggy..miggy is on duty , and clit is in preparation for paint..
and although there are holes in my fingers and they are in pain, I'm happy to loose my finger prints ;D
« Last Edit: 07 May 2011, 22:47:52 by cem_devecioglu »
« Reply #132 on: 08 May 2011, 03:17:31 »
Failed rear blind removed from another car, tested in the garage with a spare battery, found to work with power applied to motor and operate fine. Presumed failed relay box to motor. TB had one spare so took the lot up to his where we proceeded to diagnose.... A sticking motor.  :-[
I hate intermittent faults, so thanks to TB for sticking with what was hoped to be a 20 minute job that turned into a 4 hour job to swap the motor, which meant the spring loaded gear slipped round which meant taking the little gearbox apart, re locating the spring, re fitting, to find the gear was 360 degrees out and not sprung loaded, remove it again, swap the spring for a non bent one re fit, re adjust gear to line up, re fit again and bingo, perfectly working rear blind , and that's the short story, and then we had to fit it to the car.
Still working beautifully, was playing with it on the way home, even at night in p!ssing rain.
Actually that really was an unpleasant drive home, aquaplaning at 70 on the m40 in shite visibility. It was belting down.
« Last Edit: 08 May 2011, 03:18:27 by chrisgixer »
« Reply #133 on: 08 May 2011, 03:23:11 »
Oh, and removed the Bose shelf on Friday, Bose amp re sited in first aid cupboard. Smart!  :y
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
« Reply #134 on: 08 May 2011, 08:42:24 »
De badged the rear, just need to find 2 small rubber stoppers to fill the "locating" holes from the griffin badge  :-/
AKA - Mr Bracket
Pages: 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 ... 1751   Go Up
Page created in 0.048 seconds with 21 queries.
