Pages: 1 ... 82 83 84 85 86 87 88 [89] 90 91 92 93 94 95 96 ... 1444   Go Down
Author Topic: So what have you done to your car today?  (Read 1631835 times)
0 Members and 5 Guests are viewing this topic.
« Reply #1320 on: 26 November 2011, 15:19:13 »
body damage for clit repaired and finally car back at home, and refurbed wheels are in use (after a month of heating to dry the paint)..
paul.lovejoy
  • Ramsgate Kent
    • wife mad 2.6 cd estate
« Reply #1321 on: 26 November 2011, 16:34:06 »
pumped up tyre, hoovered back seat moved it around on drive and there it will have to sit until i can tax it and send it of to the pink one to work his magic via the tyre shop.
dont you just love tax bills at christmas oh to be self employed ;D ;D
Omega_Dan
« Reply #1322 on: 26 November 2011, 18:16:10 »
Changed front and rear suspension. 40mm lower on the front and 30 mm lower at the back on apex springs. Test driving it up to 85mpg feels so much better. No vibrations or wallowing about. Fitted new wishbones that put the tracking out slightly but now its fine :y
robmac
« Reply #1323 on: 26 November 2011, 20:23:53 »
fitted new eater bypass valve oping this was the source of my coolant leak but alas its still losing its coolant :-[ going to remove plenum etc tomorrow and pressure test cooling system to find the damn leak source.
marrus69
  • bracknell
    • 52 mv6 3.2
« Reply #1324 on: 27 November 2011, 08:43:12 »
oil change today.how small is the filter
« Reply #1325 on: 27 November 2011, 09:03:53 »
Pretty standard size for a petrol filter....
I own a Zafira, I'm allowed to feel depressed.
« Reply #1326 on: 27 November 2011, 15:08:38 »
Fitted the rest if the silly bolts in me wheels, checked pressures and fluids.
« Last Edit: 27 November 2011, 15:10:41 by chrisgixer - next in line »
« Reply #1327 on: 27 November 2011, 15:23:17 »
The BC moaned at me to check the oil & washer fluid yesterday, so I duly did as I was told today.. refilled the washer fluid and reminded myself that I really must do an oil change soon; it's a tad dark  :-[
« Reply #1328 on: 27 November 2011, 17:02:52 »
Put the repaired fan resistor in the Rover, and washed TBE - although it's not looking good, paintwork looks 'blotchy'  :-\
« Reply #1329 on: 27 November 2011, 17:03:24 »
Looked at the Desmond and again apologised for leaving it undriven for longer than is sensible. :-[
« Reply #1330 on: 27 November 2011, 17:30:05 »
Changed door check strap bush,lubricated door hinges,checked tyre pressures,checked fluid levels,almost finished wheel refurb.
« Reply #1331 on: 27 November 2011, 18:02:52 »
probably laquer layer become very tiny in some areas :-\   my roof/ceiling part is in 2 colors now and need re-spray at the end of this spring..
Amigo
  • Immingham N.E Lincs.
  • Be objective, be selective.
    • Passat & Cortina GXL
« Reply #1332 on: 27 November 2011, 18:57:40 »
Sold it dude!!! :D
paul.lovejoy
  • Ramsgate Kent
« Reply #1333 on: 27 November 2011, 21:06:46 »
glad you got of your arse today well done ;D ;D
« Reply #1334 on: 27 November 2011, 21:11:54 »
I was at work 7.30am - 7.30pm. ::) :-X ;D
Pages: 1 ... 82 83 84 85 86 87 88 [89] 90 91 92 93 94 95 96 ... 1444   Go Up
Page created in 0.139 seconds with 21 queries.
