Pages: 1 ... 85 86 87 88 89 90 91 [92] 93 94 95 96 97 98 99 ... 1448   Go Down
Author Topic: So what have you done to your car today?  (Read 1642782 times)
luizvivas and 5 Guests are viewing this topic.
« Reply #1365 on: 04 December 2011, 16:16:29 »
Lpg ingrctor nozels need to be smaller on TBE. 2.3mm...?
Yup, too big currently, making idle a little jumpy...
I think Bullet needs idle map tweaking. Mind you, would benefit from a firmware update as well ;D
I own a Zafira, I'm allowed to feel depressed.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #1366 on: 04 December 2011, 16:19:11 »
Is that lifter still quiet to then Ugly?  :-*
« Reply #1367 on: 04 December 2011, 16:21:41 »
I've got so used to it, I wasn't paying attention this morning when I started it to move it back on the drive ::)
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #1368 on: 04 December 2011, 16:23:51 »
;D
« Reply #1369 on: 04 December 2011, 16:24:29 »
Are ou thinking fanimold/downpipe join was the noise?
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #1370 on: 04 December 2011, 16:39:19 »
I did wonder, as you said the lifter was not making its usual noise, yet what was done would not have effected that.....
« Reply #1371 on: 04 December 2011, 16:39:39 »
You about Monday/Tuesday evening? ::)
« Reply #1372 on: 04 December 2011, 17:06:05 »
as the car converted to manual shaft balance done (expensive me thinks its 70 aprox) (some vibrations at 60 km/hr )
right and left knock sensors changed (long job really)  and starter serviced ..
Johnny English
  • Hungary
  • English antitalent
    • 1995. 2.5 V6 LPG manual
« Reply #1373 on: 04 December 2011, 17:14:37 »
Dismantled some unit of aircon at front of engine close to fan, service connector (fill up) was shoot out by overpressure. :(  Having found a used one I attempted to change them . Unsuccessfully. :( The ends of pipes are differents so I have to get it repaired by a welder who is able to weld alu aircon pipe as well. Not an easy job to find...I'm investigating away.  8) 8) 8)
Welder is found!  :y I had to do a little pre-work, I've cut down both of pipe end, fortune the outside diameter of one as the same as the inside diameter of other. So just cut a screw in and an other out and both of end could be fitted to each other.  :y I'm not sure in screws made by myself so I'm gonna get it welded properly. Welding tomorrow.  :)
C20NE - X25XE
« Reply #1374 on: 04 December 2011, 18:41:01 »
Aye.
If you had some spare nozzles, I'd have 2 to tweak ::)
« Reply #1375 on: 04 December 2011, 18:48:52 »
Had to get mine from Tilo, as none spare in the spares box.
« Reply #1376 on: 04 December 2011, 18:51:01 »
Aye.
You had all the spares ;) ;)
Not 100% sure I'll be able to make it yet... Apparently it's quite an intensive course because of the number of us on it ::)
« Reply #1377 on: 04 December 2011, 18:58:55 »
Yeah, tried calling him a couple of weeks back. Failed.
Not tried since.
« Reply #1378 on: 04 December 2011, 19:45:45 »
Not tried since.
Want me to try him tomorrow (if I get a chance!)? ???
« Reply #1379 on: 04 December 2011, 19:46:46 »
Somehow I have this mental image of TB slamming the phone down and then doing whatever the desk-based equivalent of leaving 10,000 miles of rubber is, before vowing never to call him again...
Pages: 1 ... 85 86 87 88 89 90 91 [92] 93 94 95 96 97 98 99 ... 1448   Go Up
Page created in 0.181 seconds with 21 queries.
